Page 1 of 4 1234 LastLast
Results 1 to 10 of 37
  1. #1
    Member
    Join Date
    Jul 2013
    Posts
    35
    Grand Haven, MI
    2012 Kubota B3200 HSD w/ FEL, 60 in mid mount mower and 60 in box blade
    Default Yahoo- I finally have my Kubota
    Gents,
    Yahoo- Yes, last week I finally purchased a 2012 kubota B3200 HSD w/ FEL, 60 in QA bucket and a 60 inch mid mount mower. This tractor is in mint condition and has only 30hrs of use with 90% used for mowing. I have since purchased a new County Line 60 inch BOX Blade 440 lbs w/ 5/16 steel sides. I looked at Land Pride BB1560 which weighed in a 424 lbs w/ 5/16 steel sides. Aaah, I just could not justify spending several hundred dollars more. In any event, I have only had the tractor for less than a week and so far I am very pleased with the power and exceptional performance.
    As stated in my original post a few weeks ago, I will be using the tractor for hauling wood, landscaping, grading my driveway, and snow removal. I have under an acre of grass, and I am not certain if I will keep the almost new 60 inch mid mount mower deck.
    I am also looking for your expertise and advise. If I do keep the mower, It would be much simpler to have a quick release attachment for removing and attaching the box blade. Very time consuming. What brand of quick attachment do you suggest? Is one brand better that the other? Do they work as well as advertised? I have only been a member of TBN for a few weeks and I have much enjoyed the threads.
    Thank you,
    Tobyone
  2. #2
    Super Member WilliamBos's Avatar
    Join Date
    May 2004
    Posts
    5,061
    Innisfil, Ontario, Canada
    MF 1635 12x12 Powershuttle
    Default
    Keep the mower, you will love using your new tractor for cutting grass.
    Congrats!?
    Thanks,
    Will
    2017 Ram SXT 1500 Crew Cab 4x4 5.7 Hemi 6 speed auto.
  3. #3
    Join Date
    Feb 2013
    Posts
    647
    Thornville, Ohio
    No longer Searching. Mahindra 3016 Shuttle
    Default Re: Yahoo- I finally have my Kubota
    Tobyone,
    Congratulations on getting your Kubota. I agree with Will, keep the mower deck. Look at John Deere's and Land Pride's Quick Hitches. You will need to get a set of quick hitch bushings for each rear implement that you purchase.
  4. #4
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    7,076
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    In my opinion adding Stabilworks pin-adjustable, rigid stabilizers are the premier aftermarket solution to difficult implement mounts. I mount my Rollover Box Blade, 630 pounds, on or off in less than two minutes. I often make three implement changes a day.
    Stabilworks mechs dramatically reinforce 3-Pt. hitch when pushing implements; most importantly PUSHING a Box Blade and PUSHING a Rotary Cutter. Stabilworks <$200.
    Pat's easy change are also recommended but Pat's increases your lower link length by 4", which means you may have to add 4" adaptors to PTO shafts to increase shaft lengths, you lose leveling/pivot feature of lower link "eyes" and you have to use Pat's proprietary lynch pins. No lower link reinforcement with Pat's.
    Harry Ferguson invented the three-point hitch and held patents on it 1926-1953. Once Ferguson's patents expired the "Three Point" became standard tractor-implement connection worldwide. Consider before cluttering Ferguson's brilliant design to "improve" it.
    LINKS:
    Kubota tractor stabilizers Kubota www.stabilworks.com - YouTube
    http://www.tractorbynet.com/forums/a...cult-load.html
    See if mounting tips in second link help you. If not, expand on your loading difficulties and we will coach you. Technique is half the solution.
    Attached Thumbnails Attached Thumbnails Yahoo- I finally have my Kubota-img_0463-jpg   Yahoo- I finally have my Kubota-img_0461-jpg
    The word tractor was taken from Medieval Latin, being the agent noun of trahere, "to pull, draw".
    Kubota B3300SU; no longer with me but still pulling in the community.
  5. #5
    Veteran Member RaydaKub's Avatar
    Join Date
    Sep 2011
    Posts
    2,009
    Rochester, MN
    Kubota BX2230
    Welcome to TBN and congrats on such a great rig.
    I'd keep the mower too. Unless you have another mower you like better, which I doubt. It won't take long to cut with this thing. You might find yourself cutting it twice a week just because you can.
  6. #6
    Silver Member Finnster's Avatar
    Join Date
    Jun 2013
    Posts
    164
    Bucks Co, PA
    Kubota B2620
    How long does it take you to mount the box blade?
    Considering you are just using the one implement, how much do you expect to use it? You say you have <1 acre of grass, but is there a lot more property you need the BB often to maintain?
    If money is no concern, go and get one, but sounds like you are trying to be more economical, so I'm wondering what the big payback on the QH will be.
    I have a 4 ft BB, and it takes a bit of wrestling to get on, but only takes a few minutes at that. I would look at the stableworks stabilizers first (assuming low cost) then maybe the QH.
    More than anything it may just take some time and experience to work out a good method/setup to mount the BB efficiently.
    The biggest time consumer for me is actually mounting/unmounting the whole 3ph when I want to put my backhoe on. If you are not doing that, 3ph tays on always, and just occationally use the BB for some occational but time intensive projects, not sure I would bother.
  7. #7
    Join Date
    Jun 2013
    Posts
    164
    Bucks Co, PA
    Kubota B2620
    Congrats on the tractor. Very nice setup you have.
    I would keep the mower until I was really sure I didn't need it.
  8. #8
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    A land pride quick hitch is 500$ so pats might be the way to go for you.
    Murph
  9. #9
    Join Date
    Apr 2011
    Posts
    740
    SW Ohio
    John Deere 3032E
    I like my Pat's but I did have to make a longer top link bar
    bought one @ TSC for $24 and cut it in half and welded 8" between
  10. #10
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,213
    texas
    7040 HDC 1153 fel
    enjoy your new tractor.
Similar Threads
  1. Yahoo!!!! Got tractor, etc.!!!!!!!!!!!
    By stormpetrel in forum Yanmar
    Last Post: 11-11-2010, 06:08 PM
  2. yahoo mail ?
    By chucko in forum Related Topics
    Last Post: 08-16-2005, 08:29 AM
  3. I got da Yahoo blues!
    By Wal in forum Related Topics
    Last Post: 03-24-2002, 09:45 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
