Page 1 of 3 123 LastLast
Results 1 to 10 of 29
  1. #1
    New Member
    Join Date
    Aug 2013
    Posts
    5
    Mississippi
    John Deere
    Default Help me unflip a cutter
    I have a 12 foot Rhino batwing cutter. I was clipping along a small levee with the wings up. The implement slid sideways a little and the cutter tumped over on its side. The tractor didn't roll, thankfully.
    I can't winch from from the "uphill" side. Any suggestions on how to get the cutter flipped back over? Thanks
  2. #2
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Default Re: Help me unflip a cutter
    You post a thread like this without any pics?
  3. #3
    Super Star Member txdon's Avatar
    Join Date
    Jul 2003
    Posts
    11,201
    Central Texas
    Can you release the downhill wing and let the mid section back on the ground. I agree a pic is needed.
    TXDon
  4. #4
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Is it too much to hope that it has hydraulics? If so, perhaps they could be hooked up and used to your advantage?
    (Does a 12-foot batwing without hydraulics even exist?)
  5. #5
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    As suggested by others:
    >take some photos and post
    >hook up the hydraulics and lower the wing that it is resting on (if that is the case). See if the hydraulics are strong enough to return the mower to flat.
    In my mind I see the mower on a 30* slope with the downhill wing parallel to the sloped ground and the main deck vertical. If the wing that is high is "lowered" will its weight be in a position advantageous to tipping the mower back to level?
    Is the mower all the way upside down or is it over on one of the decks? The surrounding terrain is also a factor - especially since you state that it can't be winched or, apparently, pulled out and to level ground with the tractor.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  6. #6
    Gold Member Recoveryhill's Avatar
    Join Date
    Sep 2010
    Posts
    399
    St. Croix, Virgin Islands
    Kubota L3700SU
    Rigging (mechanical engineering) any form of lifting gear, tackle, equipment for moving heavy loads over short distances, etc. and the procedures of lifting and moving heavy loads.
    Where there is a will, there is a way.
  7. #7
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    If the previously-suggested solutions aren't viable, do some research into how fire departments block up flipped vehicles to get them off of people. With a small amount of lifting ability and a lot of blocking, you can slowly lift really heavy things. But do it safely!
  8. #8
    Super Star Member
    Join Date
    Mar 2008
    Posts
    15,568
    Northern Fingerlakes region of NY, USA
    Kubota L3830GST, B7500HST, BX2660
    Need pictures, but if you have "power down" for the wings, I would try that first.
    Aaron Z
    A human being should be able to change a diaper, plan an invasion, butcher a hog, conn a ship, design a building, write a sonnet, balance accounts, build a wall, set a bone, comfort the dying, take orders, give orders, cooperate, act alone, solve equations, analyze a new problem, pitch manure, program a computer, cook a tasty meal, fight efficiently, die gallantly. Specialization is for insects.
    Robert Heinlein, Time Enough for Love
  9. #9
    New Member
    Join Date
    Aug 2013
    Posts
    5
    Mississippi
    John Deere
    Quote Originally Posted by gwdixon View Post
    I don't have pictures. I won't be back at the farm until Saturday. If I can't get it flipped back over Saturday, I'll take pics.
    The hydraulics are not sufficient to flip it back over. Tried that.
    It's not a very steep slope. It's a small levee with maybe a 3 foot gradual drop on the right side where the implement is. The ditch is on the left side so there's no available relief from that side.
    The cutter's right wing is on the ground. The middle/main deck of the cutter is more or less vertical or perpendicular to the ground. The left wing is flipped back over the top and parallel to the ground. So from a straight position with the wings up, it flipped 90 degrees to the right.
    The tractor can't move it by itself. I guess there's too much weight directly on the ground and 3 of the 4 wheels are in the air. And the slope is not helping. The tractor is nosed up the slope slightly.
    If I could get the top/left wing flipped back up and over, that would definitely help with the weight distribution.
    All I can really come up with is trying to use a farm jack or two to try to get it up and over. Any thoughts appreciated.
  10. #10
    Elite Member
    Join Date
    May 2012
    Posts
    2,972
    Knoxville, TN
    Bobcat CT225
    Can you elaborate as to why winching from the top-side isn't an option?
Similar Threads
  1. Mowing Rotary cutter leaving half cut grass on the left side of the cutter
    By DON11630 in forum Owning/Operating
    Last Post: 08-31-2015, 10:46 AM
  2. Rotary Cutter Best mowing rotary cutter "brush cutter"
    By sawtooth in forum Attachments
    Last Post: 03-14-2013, 06:48 PM
  3. Replies: 20
    Last Post: 06-18-2011, 12:08 PM
  4. Sod cutter
    By garcia in forum Build-It Yourself
    Last Post: 08-13-2010, 11:23 AM
  5. Rotary Cutter Help - Woods Dixie Cutter rotary cutter
    By RussMan in forum Attachments
    Last Post: 09-26-2007, 08:14 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
