Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Aug 2013
    Posts
    6
    London, UK
    John Deere 1030
    Default John Deere 1030 Drawbar
    Possibly a silly question. The drawbar in this picture would seems to be the wrong way up, it that correct and can it be used either way? I have seen another JD setup in the same way hence the question. I assume that it was turned this way to give the trailer slightly more ground clearance. Any help or guidance would be much appreciated.
    Attached Thumbnails Attached Thumbnails John Deere 1030 Drawbar-image-jpg
  2. #2
    Epic Contributor murphy1244's Avatar
    Join Date
    Nov 2011
    Posts
    20,593
    Ohio
    Kioti DK-40, MF-135, Ventrac 4500Y
    Default Re: John Deere 1030 Drawbar
    It shouldn't matter which way.
    Murph
  3. #3
    Super Member tcreeley's Avatar
    Join Date
    Feb 2011
    Posts
    7,996
    Hudson, Maine
    2003 NH TC30
    That twisted bottom bar- heat it in a forge, or use a large torch and hammer it straight. Have the top bar take the weight in your set up- the twisted bottom bar is just to give you 2 plates to pass the pin through. It is thin because the thicker one is the load bearing one.
    Good luck.
    NH TC30, 7308 loader, 7' snowbear plow, 5' hiller, 5' tillovator (agrisupply), International Agritech 5' towable Bushhog. dumping carryhall, camo brush trailer, 8 hp Trencherman backhoe, International disk harrow, International single plow, Sears ZTL 7000, 8hp Roto Hoe Shredder'nChipper, CubCadet 524 snow blower, CubCadet rear tine tiller, working forge
  4. #4
    Super Member TomSeller's Avatar
    Join Date
    Jan 2013
    Posts
    8,695
    JD, Massey, Kubota, Case
    Default
    Tcreeley is correct. The smaller daughter bar is bolted to the larger parent bar which would put you at risk of the bolts coming loose. You want the downward tongue load on the thicker parent bar.
  5. #5
    New Member
    Join Date
    Aug 2013
    Posts
    6
    London, UK
    John Deere 1030
    Many thanks for the information and confirming my thoughts, appreciated.
    Will give a go at straightening the "daughter" bar - thanks for the advice.
  6. #6
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,244
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    The others are correct. The twisted part known as a "hammer strap" is designed for the drawbar pin to go through both the hammer strap & the drawbar. The towed implement will have an "eye type" hitch similar to a pintle hitch. It's correct to turn the offset drawbar up or down depending on height of drawbar required.
    Attached Thumbnails Attached Thumbnails John Deere 1030 Drawbar-rwp3979________un01jan94-gif   John Deere 1030 Drawbar-np1249_________un02jan94-gif
Similar Threads
  1. John Deere 1030 Hydraulic Problems
    By Denzil56 in forum John Deere Ag Tractors
    Last Post: 07-08-2013, 11:31 AM
  2. Need a Deere drawbar
    By Green4310TLB in forum Parts/Repairs
    Last Post: 03-22-2011, 08:38 AM
  3. John deere 1030
    By Monkey1 in forum John Deere Ag Tractors
    Last Post: 12-10-2010, 07:55 PM
  4. John deere 1030
    Last Post: 11-05-2010, 04:02 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
