Page 4 of 5 FirstFirst 12345 LastLast
Results 31 to 40 of 41
  1. #31
    Super Member Larro Darro's Avatar
    Join Date
    Jun 2013
    Posts
    6,262
    Altha Fl
    3930 Ford B1750 & B7500 Kubota
    Default Re: How do you mow rough ground quickly?
    Quote Originally Posted by TomSeller View Post
    How do you drink your beer that way?
    Here is one way. Larro
  2. #32
    Super Member
    Join Date
    Apr 2004
    Posts
    6,497
    East Coast of Lake Huron
    Deere, several
    We slow down so we waste less time and money on smashed equipment.
  3. #33
    Join Date
    May 2009
    Posts
    199
    Your L3400 has a suspension seat, maybe it is froze up
    http://www.tractorbynet.com/forums/k...sion-seat.html
    ----J
  4. #34
    Elite Member foreman Etexas's Avatar
    Join Date
    Jul 2011
    Posts
    3,252
    texas
    Kubota (2010)M7040,(2012)M7040,New Holland(2004)TL100
    I have a drag that pull behind mower to help keep the pastures smooth.How do you mow rough ground quickly?-img-20130314-00197-jpg
  5. #35
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,624
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Here is my .
    Four wheel independent suspension, four wheel steer and four wheel drive.
    How do you mow rough ground quickly?-pc190001-jpg How do you mow rough ground quickly?-pc190002-jpg How do you mow rough ground quickly?-pc190003-jpg How do you mow rough ground quickly?-pc190005-jpg
    Don't worry about side hills!
    How do you mow rough ground quickly?-p4010055-jpg How do you mow rough ground quickly?-p4120004-jpg How do you mow rough ground quickly?-p9250008-jpg
    Anything steep enough to roll it, I would be too puckered to drive on!
    Out front 7' brush hog, easy to see what you are cutting.
    How do you mow rough ground quickly?-p8070005-jpg How do you mow rough ground quickly?-p4010069-jpg
    For grass and small brush, use the 90" Finish Mower out front. Mower Attachment - Bobcat Company
    How do you mow rough ground quickly?-imag1773__19290-1363622567-1280-1280-jpg
    This picture from Google Image Search.
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  6. #36
    Join Date
    Apr 2011
    Posts
    948
    New Holland Boomer 50
    Get the drinking done first!
  7. #37
    Super Member flusher's Avatar
    Join Date
    Jun 2005
    Posts
    7,359
    Sacramento
    Getting old. Sold the ranch. Sold the tractors. Moved back to the city.
    Quote Originally Posted by flusher View Post
    Disc and drag are the only way to ensure a really smooth surface. You'll have to make several passes to get it done.
    Use caution when working on hills. I assume you don't have a tractor yet based on your initial post in this thread and lack of information in your profile. If so, I'd get a tractor that permits the wheels to be adjusted for a sufficiently wide stance to minimize rollover risk.
    Good luck.
    Follow up to my previous post:
    It doesn't cost a lot to rig up a disc and drag combo. Here's one that I use on my 6-acre hayfield.
    How do you mow rough ground quickly?-offset-disc-drag-2-jpgHow do you mow rough ground quickly?-offset-disc-drag-1-jpg
    It's a 7-ft Towner offset disc that a neighbor gave me (no cost), a few tires/rims from another neighbor (no cost), some chain, a few bags of concrete and several plastic buckets for the weights on the disc (~90 lb each) and that's it. A few passes over the field makes the surface level and smooth.
    Good luck
  8. #38
    Elite Member
    Join Date
    Sep 2003
    Posts
    4,153
    New Brunswick, Canada
    Kubota L5030 HSTC, MF 5455, Kubota M120, Allis Chalmers 7010
    An old 2wd 50-60 hp tractor with a big finish mower works wonders compared to what you're using. Our fields are rough, I love jumping in our 100 hp MF vs bumping along in the 50 hp kubota. We have used a little 50 hp IH though in years past which is quite smooth too.
  9. #39
    Gold Member streamin's Avatar
    Join Date
    Nov 2006
    Posts
    383
    Conroe, Texas. Franklinville, N.Y.
    Mahindra 5035 HST
    That is good for a crop field but what if your wanting to do your yard, wouldn't you need to pack it down some afterwards? I have the same issue with old tractor ruts.
  10. #40
    Join Date
    Jun 2005
    Posts
    7,359
    Sacramento
    Quote Originally Posted by streamin View Post
    Here's how I put in the landscaping around my house.
    1) Plow the area with a middle buster and my kubota B7510HST
    2) Rototill--Yanmar RS1200 48" wide
    How do you mow rough ground quickly?-kubota-rototill-1-jpg
    3) Use my Huskee riding mower and a tire drag to bust up the large clods
    How do you mow rough ground quickly?-huskee-tire-drag-jpg
    4) Use a carpet drag to smooth and level the surface
    How do you mow rough ground quickly?-huskee-carpet-drag-jpg
    5) Use water-filled roller to compact the soil
    How do you mow rough ground quickly?-huskee-roller-jpg
    I used the riding mower for the finishing steps since the Kubota has ag tires that would mess up the planting surface.
    Good luck
Similar Threads
  1. Replies: 41
    Last Post: 09-11-2015, 01:57 PM
  2. Smoothing Out Rough Ground
    By 5thGenTexan in forum Projects
    Last Post: 07-29-2013, 10:10 AM
  3. how to smooth rough ground?
    By streamin in forum Attachments
    Last Post: 05-25-2009, 01:24 AM
  4. ROUGH GROUND
    By karman 4564 in forum Projects
    Last Post: 07-14-2007, 11:07 AM
  5. Rough Ground
    By djg in forum Owning/Operating
    Last Post: 07-21-2005, 09:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
