Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 36
  1. #21
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,559
    Foster, RI
    Mahindra 3016
    Default Re: Additional lights on 2305 ROPS
    Quote Originally Posted by mcfarms View Post
    Wow, I never thought of that, KennyD! Seems there are a couple ways of going about/around this. #1 would be to do exactly as you did, and have a dedicated switch. Knowing me, this would increase the risk of leaving them on accidentally and draining the battery. Perhaps I could locate a wire that activates when the key it turned, but what if I want them on for a short time when the tractor is off? :-) I could always go with LED instead of the 12V/55W halogens I got. I went with the halogens for the simple reason that LED's produce little to no heat in this size. Since much of my night work will be on winter evenings (which are long and dark in Maine) the halogens produce heat that will keep the light from ice/snow buildup. So, I could always put LEDs in the hazzard and headlights to reduce the draw. Seems this isn't as simple a choice as I initially thought. lol
    This is all very helpful information!!!
    Mc, LEDS do run cooler but I'm not sure where or how this urban myth came about ( I think it has something to do with some NW county getting their LED stop lights snowed over in winter) but LED's throw out enough of heat to keep them from being snowed over short of a blizzard. They'll always throw light enough for you to see in a snow storm.
  2. #22
    Platinum Member Qapla's Avatar
    Join Date
    Sep 2008
    Posts
    952
    Gator Country
    New Holland TC40D HST 4WD FEL/BH
    Just a thought .... you could install a single-pole-double-throw switch in the line that runs to the headlights. Then run a wire from that to the headlights and another to the new work lights. That way, the headlight switch will control either set of lights you want to use at a given time but not allow both to be on at the same time to prevent over amp usage.
    New Holland Workmaster 45 2WD Gear
    Massey Ferguson 240
    NewHolland 16LA FEL
    Woods BH 70-X Sub-frame Backhoe
    Troybuilt Super Bronco w/42" mower
    Husqvarna DRT 900 Tiller
    Ariens 6.5 HP String Mower
    Husqvarna HU625WT String Mower
    3 point hitch attachments:
    single plow, double plow, 5' & 6' deck mower, tiller, 2 cultivators, planter, fertilizer spreader, disk set, sprayer, and a few homemade attachments
    30 acres, 15 acres, 5 acres
  3. #23
    New Member mcfarms's Avatar
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    John Deere 2305, 200CX FEL, 52" JD Quick Hitch power broom.
    I like it, Qapla! Best of both worlds! And in case anyone wondered, I absolutely did blow the 10 amp fuse that is stock in the work light line.
    "If your outgo exceeds your income, your upkeep will be your downfall."
  4. #24
    Platinum Member Scotty Dive's Avatar
    Join Date
    Feb 2010
    Posts
    991
    Ct
    Yanmar 2020D
    Default
    MC, I had a similar problem like yours. I have a dynamo that only produces 15 amps. What I did was added a toggle switch for two forward facing LED lights, and another switch for 2 backward facing LED lights. This way I can control the headlights, the forward facing, and the rear facing all independently. This all works nicely and doesn't over push my dynamo. Additionally, the LED's throw just enough heat to melt any snow. I am in Connecticut and we certainly get our fair share of cold and snowy winters.
    Thanks,
    Scotty Dive
    Yanmar YM2020D "Git er Done Too"
    Pictures! http://s139.photobucket.com/albums/q...t=dfc00199.pbw
    Yanmar Tractor Database - Click Link, then click file and download the excel file.: https://drive.google.com/file/d/0BxR...it?usp=sharing
  5. #25
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    Ok, Scotty. Maybe I was given incorrect info. CT is pretty similar to ME in that regard.
  6. #26
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    Default
    Thank you all for your help and advice on this project!!! I got the lights hooked up and used them one evening last week. All went well until both lights vibrated loose Thurs. and fell off. I put some rubber bushings in that should help with that problem. Below are some pics! Would love to hear your thoughts and input on the final product!
    Additional lights on 2305 ROPS-forumrunner_20130914_171439-png
    Additional lights on 2305 ROPS-forumrunner_20130914_171449-png
    Additional lights on 2305 ROPS-forumrunner_20130914_171457-png
    John Deere 2305 w/ 200CX fel & quick hitch power broom.
  7. #27
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,913
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    Looks good MC
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  8. #28
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    Looks good. Are they in your eyes at all when you look back to back up?
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  9. #29
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    Default
    Not really, monroe. Especially since I blew another fuse when I was tightening the nuts over the bushings tonight. Lol
    John Deere 2305 w/ 200CX FEL & quick hitch power broom.
  10. #30
    Super Star Member
    Join Date
    Dec 2003
    Posts
    11,665
    NC
    Kubota Grand L3830
    From what you said about the nuts vibrating loose I take they are standard type metric or SAE. Have you thought of replacing the regular nuts with ones with the locking plastic inserts. I have had good results with using the plastic lockers in high vibration areas.
Similar Threads
  1. Additional work lights on 4720 with cab
    By TCowner in forum John Deere Owning/Operating
    Last Post: 11-21-2009, 01:28 PM
  2. ROPS mounted Additional Lights for 2305?
    By inspectorman in forum John Deere Owning/Operating
    Last Post: 05-11-2007, 12:16 AM
  3. CK30 Additional Lights
    By EldonC in forum Kioti Owning/Operating
    Last Post: 12-12-2005, 01:19 AM
  4. Additional lights.
    By N80 in forum Kubota Owning/Operating
    Last Post: 09-21-2005, 04:47 PM
  5. Adding additional lights
    By Oscar in forum Customization
    Last Post: 11-02-2001, 01:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
