Page 1 of 4 1234 LastLast
Results 1 to 10 of 36
  1. #1
    New Member mcfarms's Avatar
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    John Deere 2305, 200CX FEL, 52" JD Quick Hitch power broom.
    Default Additional lights on 2305 ROPS
    I would like to install some lights on the underside of the top of the ROPS on my 2305. I have read many threads on this and have been unable to find specific wiring/installation instructions. I would like to have LED floods and run the wires inside the ROPS if possible and have them work off the normal headlight switch. There are some who feel a separate switch is desirable, but I think if I am running my normal headlights, it's because I need more light. LOL Any thoughs and instructions on this would be great! I can provide pics if necessary!
    FYI, this is my first tractor and post (other than an introduction), so I appologize in advance for my lack of experience!
  2. #2
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,713
    Foster, RI
    Mahindra 3016
    Default Re: Additional lights on 2305 ROPS
    Quote Originally Posted by mcfarms View Post
    No need to apologize Mc. I did this on my JD and had them work just like you stated. All I did was to splice into wires going to the rear parking lamps which go on with the head lights. I grounded them to the mounting bolts I used to attach them to the rops and ran the wire inside the rops with rubber grommet protection as they emerged. As you are using led's , your amp draw will only be about 3 or so which should be able to be easily supported with the existing circuitry. Heck, I ran two 55 watt lights on mine which was a 9 amp draw with no problem.
  3. #3
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    I was not aware the 2305 had parking lamps on the rear, with the exception of the directional signals. Am I incorrect with that? I should probably check when I get home. If it does, I'm golden and will do as you suggest. If not, I will need another way to do it since I don't want them coming on and off with my warning lights. LOL
  4. #4
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Unless you have an upgraded alternator just remember a 2305 came standard with 20 amp model. Going with led lights on the rear may be cheaper in the long run.
  5. #5
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,713
    Foster, RI
    Mahindra 3016
    Sorry Mc but you are correct. There are no rear lights on the little guy other than the blinkers. You'll have to go from the battery (+) to a switch to the lights. Don't forget the in line fuse.
  6. #6
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    I believe there is a power source under the seat. Is that fused already and can I simply tap into that instead of going to the battery?
  7. #7
    Advertiser kennyd's Avatar
    Join Date
    Jul 2003
    Posts
    12,958
    Westminster, MD
    John Deere 3720 CAB, 455AWS
    There is a purple wire somewhere under the seat that is for the optional work light JD sells, it's operated from the headlight switch. I chose to create a new circuit for my front and rear lights that switched thru a relay directly from the battery.
    KennyD
    www.boltonhooks.com
    Bolt-On Grab HooksTM, Bolt-On Clevis MountsTM, Weld-On Grab Hooks, Specialty Chain and Rigging Accessories, Specialty Hydraulic Components, and MUCH more!
    Visit our YouTube Channel
  8. #8
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    Ok, so I did some research last night and discovered that there is indeed a tail light on my 2305; a small affair located on the bottom side of the hazzard lights. This red light stays on (solid) whenever the headlights are on. I will check on the purple wire tonight to see which one is the better option. Either way, I don't think I'll need to add a fuse to the line since both of these should be fused aleady. If people are interested I'll post some before/after pics with this as well as details as to how I did it and what the results were.
    Tail Light:
    Additional lights on 2305 ROPS-taillight-png
  9. #9
    Join Date
    Jul 2003
    Posts
    12,958
    Westminster, MD
    The main problem with using the purple wire I mentioned or the taillight wire is that the headlights have to be ON for them to be energized. When a FEL, blade, or blower is attached to the front the headlights are all but useless IMHO so why have them ON using up precious amperage from the alternator. That's why I chose to have the work lights independent of the headlights and on their own switch.
    KennyD
    www.boltonhooks.com
  10. #10
    Join Date
    Aug 2013
    Posts
    19
    Sedgwick, Maine
    Wow, I never thought of that, KennyD! Seems there are a couple ways of going about/around this. #1 would be to do exactly as you did, and have a dedicated switch. Knowing me, this would increase the risk of leaving them on accidentally and draining the battery. Perhaps I could locate a wire that activates when the key it turned, but what if I want them on for a short time when the tractor is off? :-) I could always go with LED instead of the 12V/55W halogens I got. I went with the halogens for the simple reason that LED's produce little to no heat in this size. Since much of my night work will be on winter evenings (which are long and dark in Maine) the halogens produce heat that will keep the light from ice/snow buildup. So, I could always put LEDs in the hazzard and headlights to reduce the draw. Seems this isn't as simple a choice as I initially thought. lol
    This is all very helpful information!!!
    "If your outgo exceeds your income, your upkeep will be your downfall."
Similar Threads
  1. Additional work lights on 4720 with cab
    By TCowner in forum John Deere Owning/Operating
    Last Post: 11-21-2009, 12:28 PM
  2. ROPS mounted Additional Lights for 2305?
    By inspectorman in forum John Deere Owning/Operating
    Last Post: 05-10-2007, 11:16 PM
  3. CK30 Additional Lights
    By EldonC in forum Kioti Owning/Operating
    Last Post: 12-12-2005, 12:19 AM
  4. Additional lights.
    By N80 in forum Kubota Owning/Operating
    Last Post: 09-21-2005, 03:47 PM
  5. Adding additional lights
    By Oscar in forum Customization
    Last Post: 11-02-2001, 12:49 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
