Results 1 to 9 of 9
  1. #1
    Veteran Member Marveltone's Avatar
    Join Date
    Jun 2010
    Posts
    1,491
    Somewhere north of Roseau, MN
    Fordson Major Diesel, McCormick Deering W4, Ford 1510, John Deere L111
    Default More rear ballast? That was easy!
    I've been passively looking for ways to add more rear ballast for doing loader intensive jobs for a while. What I mean by "passively looking" is I've been too distracted by other more important projects to make it a priority. Just the other day, while rummaging through the garage, I stepped over a small pile of 45lb suitcase weights I've been intending to put on the front of another tractor. "What? Weights? I wonder..."
    I picked one up, carried it over to my box blade and slipped it over one of the braces that run from the front to the back. "Well I'll be... It fits!" I quickly grabbed the others and slipped them on. Six weights at 45lbs each makes an extra 270 lbs to my 410 lb box blade equals 680 lbs. And they can come and go instantly. Why hadn't I thought of this before?
    I'll play around with this set-up the next couple days to see if they need to be clamped down at all. So far, on the smooth lawn, they stay put.
    Joe
    Attached Thumbnails Attached Thumbnails More rear ballast?  That was easy!-0904131811-jpg   More rear ballast?  That was easy!-0904131812-jpg   More rear ballast?  That was easy!-0904131812a-jpg
    Joe
    Fordson Major Diesel: Case 3-bottom Trip Plow, Case 12' Trip Field Cultivator, Kewanee 130 Disc, John Deere 1209 Mower Conditioner, John Deere 594LW Side Delivery Rake, New Holland Hayliner 273 Baler, 18' Spike-Tooth Harrow
    Ford 1510: Du-Al 105 Loader, "The Thumb" Grapple, Bush Hog RBC60 Rear Blade, Woods HC54 Rotary Cutter, Tarter 5' Heavy-Duty Hinge Back Box Blade, Buhler Farm King Y600 Snowblower
  2. #2
    Super Member
    Join Date
    Jul 2009
    Posts
    8,416
    SW WA
    Kubota BX2360
    Default Re: More rear ballast? That was easy!
    They will often hang on the sidewall, weight portion in the box, too.
    Watch that a full load of dirt doesn't push them up enough to unhook.
    Bruce
  3. #3
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,380
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    Good idea. I've been trying to find some reasonable suitcase weights for the same purpose.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
  4. #4
    Join Date
    Jun 2010
    Posts
    1,491
    Quote Originally Posted by bcp View Post
    Bruce
    I thought of the dirt issue also and will likely remove them when blading. But, since I use my FEL way more than my box blade, the occasional job of removing them should not prove to be too much of a hassle.
    Joe
    Joe
  5. #5
    Veteran Member dieselcrawler's Avatar
    Join Date
    Jan 2008
    Posts
    2,430
    New Martinsville WV
    2013 JD 3005 2001 Kubota BX1800
    If they move or rattle too much it could be as simple as putting a small ratchet strap (1-1/4" wide 500# rated type I have a dozen or so for atvs and lawn mowers) around each bundle of weights.
    Buddy of mine used half of an old clark forklift counter weight on his BB. Solid cast iron it probly more than doubled the weight of the BB, which spends most of its time on the back of his kubota L4310 due to a lot of loader work. We loaded logs with it yesterday... 3 truck loads.
    Greg AKA DieselCrawler
    2013 JD 3005 4x4 w/loader, 530 squirrel power diesel, with gravity power-reverser
    2000-ish Kubota BX1800HST
    Trucks:
    1999 F250 Ext cab SB 4x4 7.3L diesel 6spd.
    2000 Excursion 4x4 7.3L diesel, wife's ride
    2002 F250 Ext Cab LB 4x4 7.3L diesel 6spd
    2000 F250 Crew Cab 4x4 gas/auto
    Project Extended Crew Cab SB, will get one of the 7.3/6spd drivetrains
    Redheaded wife, 7 kids, 5 horses/ponies, some cats, 4 dogs
    SEMPER PARATUS
  6. #6
    Gold Member
    Join Date
    May 2011
    Posts
    300
    Lebanon, TN
    Kubota GL3240
    Nice, I have got to do something like this or make a dedicated counter weight. None of my attachments are heavy enough to keep the rear from picking up except for the bush hog, but I don't like running around with it on.
    Grand L 3240. TSC 6' Rough Cutter, 66" Bradco Rock Bucket, 7' Fred Cain Rake, 6' United BB, Northern Tool 16 Gal Sprayer, 42" Pallet Forks Land Pride FDR1672 Finish Mower. Still looking for more attachments
  7. #7
    Silver Member dakotagun's Avatar
    Join Date
    Jul 2012
    Posts
    127
    JD 2305
    I do the same thing, mine hang on without clanging nor getting in the way, although I do need to hang more on there than there's room - maybe i'll have a support bar welded across to accommodate more weights. i'd get a ballast box but having the BB on the rear allows me to move material in combination with the FEL, not afterwards. I don't move trees and such, mostly dirt/gravel so I use the combo often.
  8. #8
    Super Member Coyote machine's Avatar
    Join Date
    May 2009
    Posts
    7,203
    Southern VT
    '10 Kioti DK 40se/hst KL-401 FEL, loaded tires, KB-2485 bhoe, Tuffline TB160 boxblade, Woods QA forks, MIE Hydraulic bhoe thumb & ripper tooth, Igland 4001 winch, & GR-20 Log Grapple. Woods BBX72" Mower. Diamondplate aluminum canopy.
    Quote Originally Posted by Marveltone View Post
    Joe
    Does BBing the lawn work better than a lawnmower?
    2010 DK-40se/HST, KL-401 FEL, (reversible cutting edge). Titan Tree Shear. 72" Ratchet Rake. Fit Rite: Top-N-Tilt hydraulics & diverter. HLA Series 2000 7' plow, Aquiline MPC rear chains. Samuri Sickle bar.
    2016 Mechron 2200PS. 2016 Cub Cadet Pro Z 160 AW Steering, Kawa 23.5HP. 2015 Husky 322T AWD Rider, Combi 103 deck. Dr. Brush mower, & 42" lawn deck, & Dr. 6.5HP Trimmer/mower.
    Bunch of STIHL chainsaws: 011x 2, MS192T, MS200T, MS180C, MS230, MS270 (Wood Boss), 038 Farmboss.
  9. #9
    Join Date
    Jun 2010
    Posts
    1,491
    Quote Originally Posted by Coyote machine View Post
    Not only does it leave a smooth finish, but it also drags the clippings off to the compost pile.
    Joe
    Joe
Similar Threads
  1. Rear Ballast Gentlemen, Rear Ballast
    By General Lee in forum Owning/Operating
    Last Post: 09-05-2012, 10:39 PM
  2. Widen rear wheels, easy or hard?
    By qstott in forum Owning/Operating
    Last Post: 01-12-2012, 09:50 PM
  3. Ballast Injector For Rear Tire Ballast
    By shadow in forum Tires
    Last Post: 03-06-2004, 09:44 AM
  4. Rear Blade Using Rear Blade with Rear Ballast
    By cbh in forum Attachments
    Last Post: 10-11-2003, 07:27 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
