Page 2 of 24 FirstFirst 1234512 ... LastLast
Results 11 to 20 of 240
  1. #11
    Elite Member
    Join Date
    Dec 2003
    Posts
    2,738
    Middle TN
    Kubota L4330HST
    Default Re: How do you fuel your tractor (logistics, not finding the cap to the tank)?
    - Jay
    Attached Thumbnails Attached Thumbnails How do you fuel your tractor (logistics, not finding the cap to the tank)?-fuelfill2_web-jpg
  2. #12
    New Member victormh's Avatar
    Join Date
    Jul 2012
    Posts
    23
    Isabela,PR
    TYM 293HST with TX2000 FEL
    I use my tractor mostly weekends, a 5 gallon can can last sometimes a month(my tractor is a 3 cyl 29hp engine) what I being doing recently is taking my 5 gallon can and pouring it partially in a 2 gallon can which is easier to handle.
  3. #13
    Elite Member RalphVa's Avatar
    Join Date
    Dec 2003
    Posts
    4,875
    Charlottesville, VA, USA
    JD 2025R, previously Gravely 5650 & JD 4010 & JD 1025R
    This 1025 is easier than the 4010. On the 4010, I had to lift a 5 gallon container up onto the hood and then do a hand-pump-start siphon (from TSC). Now, I only lift the container onto the seat.
    My generator belly tank holds 60 gallon. I refuel the tractor from it, using a little 12v pump to fill my 5 gallon container. If I got a long piece of tygon tubing, I could fill the tractor directly from the tank, but using the 5 gallon container gives me an easy check of fuel consumption.
    Then every so often I run to the fuel station and pick up another 4+ containers of fuel and put into the generator tank. I can hand siphon into the tank with the containers sitting on a short step ladder. Some of these days, I'll maybe get a 20 gallon container to put into my pickup. Need one that'll fit onto the bucket of my tractor. Don't want to invest in forks.
    The natural gardener
    God's original intent
  4. #14
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    EZ-POUR
    See link above for how to replace your idiot caps.
    I use 5 gal. plastic cans. My tank cap is about as high as the seat back, so it is not handy for a full jug, but I can manage it. I take the EPA cap completely off and pour into a large funnel.
  5. #15
    Platinum Member Utopia Texas's Avatar
    Join Date
    Aug 2013
    Posts
    670
    Brookshire & Cat Spring,Texas
    Kubota 2650 & New Holland T4.75
    Besides not having a shut off control the harbor Freight diesel transfer pump does not have any type of screw on canister filter. I take two 55 gallon drums once a year to my local bulk dealer, load and unload from a flat bed trailer with the front forks. I have a unknown ancient 12v pump I have used with great success and it does have a screw on diesel filter which I really would not do without. I know the individual tractor engines have the smaller filter before the injector but I am not one to take chances. Diesels are expensive to get repaired....
  6. #16
    Elite Member Sysop's Avatar
    Join Date
    Jun 2013
    Posts
    3,056
    Fairmont, WV
    Mahindra 4035HST purchased 2013 - Craftsman 42" HST purchased 2003
    I second the vote for the 5 gallon cans for your uses. If you're only running the tractor on the weekends, it's not often you'll need more than what you can carry in a can or two. Not sure where your filler is, but I like a can with well rounded corners on the bottom so I can set the can down and lean to pour. I have more issues with my small lawn tractors than my big tractor, it works out so I can prop a leg up on the step, set the can on my leg, and lean it right into the filler. In my case also I like the "spillproof" option on my can, because I can get the can turned up and the filler tube on the can into the filler of the tractor tank before enabling the flow from the can.
    Avoid galvanized steel cans for diesel storage, there can be some reactions inside the can with the galvanization that will cause it to come out in your fuel system and cause costly repairs.
  7. #17
    Super Member Larro Darro's Avatar
    Join Date
    Jun 2013
    Posts
    6,262
    Altha Fl
    3930 Ford B1750 & B7500 Kubota
    Growing up we had two of the 200 gallon tanks, one each for ORD and ORG. As we got to using less, the oil company stopped home delivery. So we took a fifty five gallon drum to them to get diesel, loading and unloading it and the pallet it sits on with the hay forks. My sister and BIL have been doing more farming than me, so they had the drum and hand pump at their place. I use three five gallon gas cans, buying ORD at our local bait shop. {you can pick up fifty crickets at the same time, and if you go fishing instead of mowing, you won't use as much diesel} One of the old ones, and two of the ones that don't work. The bad thing is the threads are not the same, so I can't put the good spout on the new cans. Until I learned to only put four gallons in them, I siphoned about half of it into the good can, then poured the rest without the spout. I do it free hand, and so far haven't spilled much.
    When I was just using the B7500, five gallons would last forever. But since I bought the 6' RFM and have been using the 3930 more, I have been having to deal with it every two or three weeks.
  8. #18
    Super Member buckeyefarmer's Avatar
    Join Date
    Jun 2005
    Posts
    7,225
    MD
    Kubota L3940 L5030 MF205-4
    ole yellow used here.
    2010 - L3940HSTC, QA FEL, BH92
    2010 - Husqvarna YTH24V48LS (the other orange)
    2005 - L5030HST,QA,FEL
    198x - MF 205-4
    1990 - Wheelhorse 212H
    2017-ratchet rake, 2008-KK Tiller, 2006-Pallet forks, 2002-Carryall, 2000-PHD, 1999 - Trailer, 1999-6' rotary mower, 1999-cultivator, 1998-KK Finish Mower, 1998-Blade,1992 - Troybilt tiller, 2 wheel barrows, assorted gardening tools,
    http://www.tractorbynet.com/forums/r...life-farm.html
  9. #19
    Platinum Member Egbert's Avatar
    Join Date
    Aug 2013
    Posts
    941
    Alaska
    JD LX188
    For myself, I find holding/pouring gas cans above the hood of the tractor to be awkward and usually messy. I don't go through huge amounts of fuel but I still appreciate easily rolling my caddy beside the tractor, placing the hose in the tank and turning a handle. Takes only a minute and I'm not dragging out a ladder or balancing myself on the FEL.
    I just add Stabil to the caddy and never worry about storing the diesel.
  10. #20
    Elite Member 4shorts's Avatar
    Join Date
    Jul 2008
    Posts
    3,253
    Bay Roberts, Newfoundland
    Kubota 5740,BX25D
    I used to use yellow Jerry cans when we had just the one tractor but when the second one came along I went with the 55gallon drum and the 120 volt pump. Works well for me.
    ...Excellence is not a skill. It is an attitude...
    Check us out on the web at www.specialtyrepairscustommods.com
    YouTube Video's: http://www.youtube.com/user/7863348?feature=guide
    2011 Kubota 5740/854 FEL/L2674 Blower/Artic Angle blade with 3rd function set up,Rain Tracker Wiper system, custom built vertical exhaust,Grammer Air Ride Seat and other custom stuff
    2013 Kubota BX25D with many mods
    Kubota ZTR ZG 222 Z
    Custom Toyota Fork Lift
Similar Threads
  1. Ford 3000 vented fuel cap?
    By Oldhamhunter in forum New Holland Owning/Operating
    Last Post: 08-20-2013, 06:44 PM
  2. Does any vendor make a locking fuel cap for a JD 3038E?
    By scobrado in forum Parts/Repairs
    Last Post: 05-15-2013, 01:05 AM
  3. Got the fuel container spout out of tractor fuel tank
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 05-29-2012, 06:43 AM
  4. NEED A TANK FOR YOUR TRACTOR FUEL?
    By LBrown59 in forum Oil, Fuel & Lubricants
    Last Post: 12-07-2008, 09:57 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
