Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Jul 2013
    Posts
    18
    brookneal,va
    1953 Ford Jubilee
    Default 53 jubilee stalling
    i have a 53 jubilee. after plowing for some time, the tractor seems to be running wrong. when i give it gas, it wants to shut off. also, when i let off the clutch to move, the tractor lags then jumps in or sometimes shuts off. the spark plugs seem to be fine. i took the drain off the bottom of the carb and drained a little, which helped a little. what is the most common cause? what do i need to check next? thanks!
  2. #2
    Super Star Member
    Join Date
    Apr 2009
    Posts
    12,795
    nowhere, md
    Hanomag
    Default Re: 53 jubilee stalling
    Restriction in the fuel line, crud or water in the fuel tank, carburetor needs cleaned & float adjusted. Vacuum leak around the carburetor or intake manifold gaskets. Air filter too dirty.
    Those are my guesses of places to look.
  3. #3
    Elite Member
    Join Date
    Jun 2012
    Posts
    3,953
    Waynesboro Va
    John Deere X310, JD LA 145
    Check the sediment bowl, cut off fuel and dump it. sounds like it might be it.
  4. #4
    Super Star Member brin's Avatar
    Join Date
    Jul 2009
    Posts
    10,866
    Georgia - Mt. Vernon by The Store just 5 miles east and right by the big oak tree then to the creek.
    Quote Originally Posted by Ed of all trades View Post
    I agree...when I had my Jubilee that is the problem I had...somehow I always found cotton like fiber in the fuel filter and lines....once cleared it was fine for awhile and it would have the same problem again...I ended up selling it...What really needed to happen in my case was for the tank to be removed and cleaned and all the fuel lines cleaned out ...once and for all...but I had a neighbor who wanted it before I could do that ...he said he would do it but I don't know if he ever did..
    Bob
    WORRYING does not take away tomorrow's TROUBLES, it takes away today's PEACE.
    NH - TC-29 , FEL, Bush hog, Bush hog brand finishing mower, Post hole digger, 6' Back blade, sub-soiler, Pallet forks, 20KW PTO Generator , 21 hp Murray Mower
    JD -3020 with FEL and a 16 HP. K-Grow Lawn Tractor (bought from K Mart 1994) and runs great !
    Clark 130 EN Mig Welder
  5. #5
    New Member
    Join Date
    Jul 2013
    Posts
    18
    brookneal,va
    1953 Ford Jubilee
    thanks for the help. it ended up being gunk in the filter inserted in the side of the carb. who knows the last time it was cleaned, i just bought it 2 months ago
  6. #6
    Old Timer Soundguy's Avatar
    Join Date
    Mar 2002
    Posts
    52,722
    Central florida
    ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
    glad you figured it out.
    from now on.. when you have a run time error. start with checking spark.. if spark is ok.. move on to fuel ( the air, then compression and timing ).
    If you have only had her 2m.. she's new.
    should do a complete service and tune up as a baseline.
    souNdguy
    sent from my NOKIA LUMIA
Similar Threads
  1. jubilee
    By HFD18 in forum Parts/Repairs
    Last Post: 04-14-2011, 11:13 AM
  2. Jubilee or 8n
    By bell103 in forum Buying/Pricing/Comparisons
    Last Post: 04-28-2009, 10:14 AM
  3. 53' Jubilee Value
    By TillerofdaEarth in forum General Vintage Tractors
    Last Post: 04-19-2006, 10:25 AM
  4. What to ask when looking at a Jubilee?
    By GabeTX in forum New Holland Buying/Pricing
    Last Post: 06-13-2005, 03:22 PM
  5. What to do with '53 Jubilee NAA
    By texbaylea in forum General Vintage Tractors
    Last Post: 03-29-2005, 06:28 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
