Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. #11
    Silver Member RBA50's Avatar
    Join Date
    May 2012
    Posts
    201
    Goldendale, WA
    Kubota B2320
    Default Re: Moving backhoe over ditch
    I'm Confused (easy enough to do). Is this a circular ditch? If not, I would begin filling at one end, and as the ditch is filled back over (straddle) the ditch that has been filled. Once it's filled there should not be a problem with collapse. Just don't back past the filled area, and use the reach of the backhoe to stay as far away as possible from the open area. Also curious about the size of the rock. If you can't fill from the end, the FEL would be my choice.but as noted above, the large rock could be damaging to the pipe.
  2. #12
    Join Date
    May 2004
    Posts
    882
    Harpers Ferry WV
    Kubota L4330, 6 rear remotes
    Not sure I understand the ins and outs, but: fill liberally to 8 feet (i.e., level) in places where you need support, or to cross, and then remove two feet from those "overfilled" areas and re-position stone ? I can see needing to cross the ditch from time to time, but no need to straddle: "over"-filling stone w. bucket and then nudging it w. hoe can be done from sides, no? ...or, am I misunderstanding?
  3. #13
    Member
    Join Date
    Jul 2012
    Posts
    48
    Harford, Maryland
    Ford 550 TLB
    The ditch is 8 feet deep, filled 6 feet with the big stone, then pipe, then backfilled. I have no idea why so deep, stone size, etc. that is what the health dept. wants. The reasons for crossing are that we are building in the woods, and we had to remove a bunch of trees to install the system. If we removed a stump, there may be a hole of very soft soil as big as 6-8 feet around. I will not get my FEL close to that. 14,000 lbs I am sure the sides will collapse. Thus we over filled the trench with stone and I need to cross it to spread the stone. Even with a backhoe that big stone does not want to move. Hand leveling is out of the question.
    Due to the depth of the trench we can dig a little then spread the stone but I can only fill so far before the stone starts to get in the way of digging.
  4. #14
    Join Date
    May 2004
    Posts
    882
    Harpers Ferry WV
    some sort of dragline bucket arrangement to move/level stone?
  5. #15
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    18,199
    Central Ohio
    Kubota MX5100
    I am confused as all get out too.
    Have you dug the ditch yet?? Thats easy to do without crossing anything, start at one end and go toward the other.
    What is the issue with filling that you cant use the front end loader. Probably lots faster than the hoe anyway.
    Dig the trench, fill with stone with the FEL, lay pipe, then backfill with dirt with the FEL??????
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  6. #16
    Super Member dragoneggs's Avatar
    Join Date
    Jun 2013
    Posts
    8,315
    Seabeck, Washington
    Kubota BX-25D, Z122RKW-42, and JD LTR166 Lawn Tractor
    Quote Originally Posted by LD1 View Post
    Yeah it seems simple and obvious... I am thinking the OP is worried about caving in being too close and getting tractor stuck, IDK.
  7. #17
    Join Date
    Apr 2008
    Posts
    18,199
    Central Ohio
    Kubota MX5100
    Yea. Seems simple and straight forward to me. Dig the trench, fill all but 2' with stone, lay pipe, backfill, then spread the leftover dirt
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #18
    Veteran Member Mechanos's Avatar
    Join Date
    Aug 2010
    Posts
    1,103
    Roosterville, MO
    JD 955/70A/7 TLB
    It's easy if your FEL has an antigravity bucket.
    Moving backhoe over ditch-13842242204040-jpg
  9. #19
    Veteran Member workinallthetime's Avatar
    Join Date
    Nov 2006
    Posts
    1,079
    Tulsa, ok
    b3030 TLB,zd326
    what area of the country requires a leach field to be 8 feet deep? around here we are not allowed to go deeper then 4 feet due to the septic contaminating the ground water. Is this the tight line from the house to the tank? or the field pipe? i think code here is 300 feet minimum with additional 100 feet per full bath.
    crossing a ditch with a bh is pretty easy when absolutly necessary, if the machine cant handle it rent one that can for a day or so.
    remember pay day is on friday, dont lick your fingers and effulent runs down hill but not more than 1/4 inch per foot!!
    equipment = L45 tlb, zd326p
    attachements = disk, pallet forks, box blade, 4n1, thumb, ld material bucket
    past equipment = b???? old slow no p/s, bx23 tlb, b3030 tlb, mf 175, jd301a
  10. #20
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by Claytonfarms View Post
    I think you are overly concerned about the stump holes, use your backhoe to tamp the holes and compact them. Over filling the trench was a mistake imo. but might be a good place to use to straddle the ditch.
    Lots of problems and issues with this ditch, unless the percolation if very good 60 ft of trench isn't much and may cause premature failure of the field. The stone seems to be too large to be in contact with the field pipe and will be hard to smooth and grade. If you do get it smoothed out and pipe in place you might want to add a layer or two of landscape cloth to keep the dirt out of the rock layer when backfilling.
Similar Threads
  1. straddling a ditch with backhoe
    By swick1 in forum Owning/Operating
    Last Post: 01-04-2012, 11:12 PM
  2. Ditch Witch 6510 trencher/backhoe
    By WantedWolf in forum Ag Tractors & Machinery
    Last Post: 11-08-2009, 02:56 AM
  3. Screw the Backhoe for the Oozama Ditch! Or, ...
    By glennmac in forum Projects
    Last Post: 06-25-2003, 11:27 AM
  4. Backhoe Digging A Ditch Without Backhoe
    By Harv in forum Kubota Owning/Operating
    Last Post: 10-02-2000, 07:42 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
