Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
  1. #21
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    9,284
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    Default Re: Cant hook up bushhog..
    I'm SHOCKED!! YES SHOCKED!!
    The obvious solution is you buy a tractor for each implement!!
    That's what I'm trying to convince my wife anyways
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  2. #22
    Super Member rlgustafson's Avatar
    Join Date
    Dec 2012
    Posts
    6,174
    Weimar, Texas
    NH TL-100A with Bush Hog 5045 FEL, WR Long 3rd function, LS XR4155HC w/FEL, WR Long 3rd Function.
    Both of our Bush Hogs are supported by blocks under front corners when not on tractor. Makes hookup very easy. We have Delta Hooks on all the Cat 1 equipment and the kubota tractor so, other than hooking up PTO shaft, takes just a few seconds. Have Speeco QA on the New Holland but, unfortunately a few of the Cat 2 implements are not QA compatible. Will be some welding work for this winter.
    Rick
  3. #23
    Join Date
    Sep 2010
    Posts
    66
    Ford 5000
    Quote Originally Posted by k0ua View Post
    A picture would be worth, a thousand words... bars? do you mean the 7/8 inch pins that the lower links slip on? If so.. no. Nothing should be bent.
    Cant hook up bushhog..-threaduselesswithoutpics-jpg
  4. #24
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Here's a pic of my 3pt setup with the adjustable stabilizers that I purchased from Mark Hodges at StabilWorks
    Note that my adjustable lift arm on the right is not original. Mine bent then broke so I fabbed up a new one from a cat 0 top link and the forks from the old one.
  5. #25
    Elite Member Bob77064's Avatar
    Join Date
    Sep 2011
    Posts
    3,972
    KY @ TN line
    2011 LS R3039
    Cant hook up bushhog..-carterezhitch-jpg
    This is a picture of the Carter EZ hitch I got, they work very well.
  6. #26
    Join Date
    Oct 2013
    Posts
    53
    clarkesville georgia
    LS G3038, stihl fs90, stihl ms290, snapper riding mower, Honda gcv160, Yamaha g9 golf cart
    Thanks everyone, I got it hooked up!
  7. #27
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Quote Originally Posted by skytime24 View Post
    Good!
  8. #28
    Join Date
    Sep 2009
    Posts
    1,007
    Southeast La.
    Kubota 2320
    What did you do to get it done ?
    There are old sailors and there are bold sailors, but there are no old, bold sailors.
    B2320, 48 " Woods Brushbull, LA304 loader, modified Kingkutter carryall, Middle Buster
  9. #29
    Join Date
    Oct 2013
    Posts
    53
    Quote Originally Posted by sailorman View Post
    Put the left lower link on the tip of the bush hog pin then used the bar to move the left side of the hog forward a bit then it slid on, same for the other side
  10. #30
    Super Member
    Join Date
    Sep 2000
    Posts
    6,596
    Default
    Just remember.... when in doubt use a bigger lever.
    When I have issues, it's usually due to dropping the attachment at a funny angle, in a hole on one side, where the tractor wants to roll away or all of the above. I try to pre-plan and leave implements so hookup is easier.
    To make a heavy implement easy to slide, screw a 8 foot long 1/4" square tube to a board or post. Steel on steel moves easy.
Similar Threads
  1. need help with hook ups on john deere 750 to hook up FEL
    By krisbodean85 in forum John Deere Owning/Operating
    Last Post: 04-18-2013, 07:38 AM
  2. hydraulic bushhog
    By ebeacham in forum Hydraulics
    Last Post: 07-04-2012, 04:44 AM
  3. Chained Bushhog
    By RSKY in forum Attachments
    Last Post: 12-22-2011, 04:33 PM
  4. bushhog
    By riverhunter in forum Kubota Owning/Operating
    Last Post: 11-15-2011, 08:16 PM
  5. bushhog 5 ft.
    By fwill in forum Attachments
    Last Post: 08-24-2005, 03:17 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
