Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
  1. #11
    Platinum Member RoMad's Avatar
    Join Date
    Oct 2010
    Posts
    563
    Lecanto Florida
    Kubota L3710
    Default Re: Easy way to drain tires?
    If you just want to add antifreeze why do you need all of the water out? Why not just remove as much water as you plan on putting in antifreeze.
  2. #12
    Join Date
    Feb 2007
    Posts
    1,635
    easten Colorado
    JD 4020
    put the valve core down air it up and take out The core, it will may take a few airing up to blow out the liquid, if there is a tube one can use tube deflator on the stem (with the core out), it will vacuum the air and liquid out, but if no tube, one can unset the tire and vacuum it out with a shop vacuum,
    tube deflator
    https://www.google.com/search?q=Milt...w=1280&bih=800
  3. #13
    Super Star Member
    Join Date
    Feb 2008
    Posts
    12,465
    somewhere usa
    Deere 110tlb, 4520, x749, L130
    Quote Originally Posted by RoMad View Post
    I agree with this since the OP explains why he is trying to get the water out, that wasn't clear in the first post.
  4. #14
    Join Date
    Oct 2013
    Posts
    149
    Eastern Indiana
    JD 850 & 4310
    Thanks for the suggestions!
    Yes they are tubeless and I have drained what I could by turning the rim so the valve stem was at the bottom and then drain, fill with air, drain and so on. What I have left is just the water that is in the bottom 25% or so of the tire. I'm guessing around 5 gallons or so in each tire.
    I would prefer to drain ALL of the water out and that is why I am tapping into the collective knowledge to find out if anyone else has ever done this. The reason I mentioned filling with antifreeze was because If I could not find a way to drain the remaining water I would just fill the tires back up with antifreeze or wiper fluid so the water did not freeze and cause problems.
    My main goal here is to get the water out of the tires so it doesn't freeze. Also I am trying to get as smooth a ride as I can while mowing. That being said, I don't really think that it matters if these R-4 tires are filled or not. They are STIFF!!! I let the tractor down off the jack yesterday with NO air pressure in the tires and you could not see any bulge in the sidewall. If I had a flat I don't know that I would even notice.
    I will probably look for a small tube that will fit down into the bottom of the tire through the valve stem like someone mentioned earlier. Anyone have any suggestions? I'm not even sure what the diameter inside the valve stem is.
    Thanks again
  5. #15
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,462
    VA
    JD2010, Kubota3450,2550, Mahindra 7520 w FEL w Skid Steer QC w/Tilt Tatch, & BH, BX1500
    Quote Originally Posted by jenkinsph View Post
    ......Nope. He wants to get the water out :
    Quote Originally Posted by 4310 View Post
    They are not tubed and are just filled with water. I have to either empty or add some antifreeze to them now that the tractor is back up here (Indiana).
    Last night I drained the majority of the water through the valve stem but I couldnt get what was below the stem.
    I have thought about using a small tube to siphon most of it out and have kicked around the idea of drilling a hole. These tires arent in the best shape anyway and I could probably just drill through one of the repair plugs that are in it already. Anyone tried that route?
    I have also never fooled around with taking the valve stem off the rim and I'm not sure how those are put together. These are metal. If I unscrew them is there something that will fall back inside the tire?
    This side of 40
    JD2010, Kubota L3450/FEL w SK QC, L2550 w FEL
    Mahindra 7520 [Pinky] /FEL w Skid Steer QC/w Tilt Tatch & BH, BX1500 [Mighty Mouse]
    IH37 Baler, CCM165 Drum Mower, JD Rake
    JD 127 bushog, Flail, SK Tilt Tatch , KK tiller, Rhino rear blade, Post driver, post auger, chipper, pallet fork, Grapple/Loader Buddy, Homemade Splitter/DC Welder
  6. #16
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,462
    VA
    Thanks again
    You could find one close, somewhat stiff, and then wrap electrical tape to shim it. You want as little air leak as possible so you dont have to air it too many times.
    This side of 40
  7. #17
    Join Date
    Oct 2013
    Posts
    149
    Eastern Indiana
    JD 850 & 4310
    Thats what I was thinking. The only thing that comes to mind is a loooong coffee stirrer stick/straw thing.
  8. #18
    Super Star Member
    Join Date
    Feb 2006
    Posts
    12,462
    VA
    Hardware store would probably have 1/4" OD semi rigid tubing.
    This side of 40
  9. #19
    Join Date
    Oct 2013
    Posts
    149
    Eastern Indiana
    JD 850 & 4310
    Default
    Easy way to drain tires?-image-3856546906-jpg
    Well here's what I ended up doing (if the picture shows up). I found some rigid aquarium tubing about 15" long or so and attached some regular aquarium tubing onto that.
    I was hoping to just let it siphon out but air bubbles kept forming to the inside of the tubing which slowed the already slow flow. I ended up putting tape over the end of my shop vac hose and sticking the tubing through that. It sped things up but still took about half an hour per tire to do.
    If I had found some slightly bigger tubing I'm sure it would have made things even quicker but that's what I had lying around. I did try using a heavy plastic straw like thing that fit perfectly inside the tire valve thing but I noticed that when I hooked it to the shop vac it created negative pressure inside the tire. I was afraid that it would suck the bead off the rim.
    Also I found that the valve is a two piece thing. I took my pliers and unscrewed it from the piece attached to the rim.
Similar Threads
  1. L3800 wider stance w/ rear tires, how easy to do?
    By redsox1 in forum Kubota Owning/Operating
    Last Post: 04-25-2013, 07:27 PM
  2. Making drain holes in old tires
    By BeezFun in forum Projects
    Last Post: 04-15-2012, 03:51 PM
  3. Easy tool to add Slime into tractor tires
    By krackerjack9 in forum Parts/Repairs
    Last Post: 06-26-2008, 09:58 PM
  4. Any easy way to drain PS hydraulic oil on 304?
    By jinmajim in forum Chinese Tractors
    Last Post: 04-08-2005, 10:07 AM
  5. Tires Self loading of tires easy!
    By Anonymous Poster in forum Owning/Operating
    Last Post: 08-15-2002, 09:37 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
