Results 1 to 6 of 6
  1. #1
    New Member
    Join Date
    Nov 2013
    Posts
    3
    Beebe AR.
    Kubota m9540
    Default 9540 kubota steering problems
    I have a 9540 kubota 2012 model with 815 hours. The tractor is equipped with a hyd. shuttle and a 24-24 trans. At 300 hours the steering got very heavy and rough at times you have to steer hand over hand. Tractor has been in the shop at two different dealers a total of eight times. Kubota field service reps. have also been involved and came to my farm twice. At present steering is getting worse and the Kubota rep. has told me that I will have to just live with it. I don't think so. Is anyone else having steering problems? G Moore Beebe Ar.
  2. #2
    Super Member Tx Jim's Avatar
    Join Date
    Jan 2007
    Posts
    7,090
    Coyote Flats,Tx
    JD 4255/Kubota M7040 HDC
    Default Re: 9540 kubota steering problems
    My '11 M7040 with 504 hrs just started having stiff steering. I posted a question on kubota forum but no one responded.
  3. #3
    Join Date
    Mar 2008
    Posts
    1,161
    southwest NH
    Kubota L5240
    Have them check the power steering suction hose. Had a friend had one fail on his 5240. It may suck in under load and look normal when parked. Good luck !
    'Master of a thousand indispensable skills destined to keep him at the poverty level'
    'You can't beat a man at his own trade'
  4. #4
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,388
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    There was a post on here a while back with a larger M having steering trouble and I think it turned out to be the priority valve. But being to the dealer 5 times that should of been found if that is it. Have they told you what they have tried?
  5. #5
    New Member
    Join Date
    Nov 2013
    Posts
    3
    Beebe AR.
    Kubota m9540
    They changed the hand pump, steering cylinder,and priority valve with on results. The latest visit to the shop hyd. pressure was maxed out on hand pump, steers worse and hyd. chatter is very loud.
  6. #6
    New Member
    Join Date
    Nov 2013
    Posts
    3
    Beebe AR.
    Kubota m9540
    Will do. Thanks
Similar Threads
  1. Kubota M8200 steering problems
    By Leghumper in forum Parts/Repairs
    Last Post: 10-04-2012, 01:40 PM
  2. Kubota 9540
    By Mack82 in forum Kubota Buying/Pricing
    Last Post: 02-27-2012, 07:34 PM
  3. Kubota M8540/9540 Steering Column Grease Fitting
    By clee4020 in forum Oil, Fuel & Lubricants
    Last Post: 08-08-2011, 03:16 PM
  4. hydrostatic steering problems kubota b3030
    By WaxMan in forum Kubota Owning/Operating
    Last Post: 07-03-2009, 03:44 PM
  5. Kubota L3600 Steering Problems
    By krickard in forum Kubota Owning/Operating
    Last Post: 12-23-2002, 01:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
