Page 3 of 6 FirstFirst 123456 LastLast
Results 21 to 30 of 58
  1. #21
    Silver Member corl's Avatar
    Join Date
    Mar 2012
    Posts
    171
    West Grove, Pa
    2013 Kubota MX5100 HST, 1989 Kubota F2100
    Default Re: Wife tells me that we need a bigger tractor!
    There was a thread on unrolling vs round bale feeder on this forum
    http://www.tractorbynet.com/forums/h...unrolling.html
    Lots of thoughts but more work was not part of the discussion. I would agree that if you just have a few horses to feed a round bale feeder is better.
    If you are planning for the long run you should get a FEL tractor that can lift a real round bale 750 - 1000 lbs. Your source of little round bales may disappear and then you are looking for a larger tractor again. If you only put 450 hrs on your tractor over a period of 8 years and economics is important I would look at a used
    tractor of the right size. If that is not important go for a new one.
    I got my first new tractor last year after 40 years of used tractor use that was very successful. Fed round bales to cows for over 30 years. Had a IH574RC tractor with FEL and bale spear. Good for all haying operations. Was a good investment.
  2. #22
    Platinum Member Iowan's Avatar
    Join Date
    Oct 2012
    Posts
    713
    North Central Iowa
    Kubota's
    I tell my wife I need a bigger tractor and she gets bigger! She's gone from a BX to Grand L in the last eighteen years.
  3. #23
    Elite Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    4,179
    SouthEast Michigan
    Massey 1652 HST Cab
    Default
    Quote Originally Posted by Iowan View Post
    Lol! That's hilarious.
    Wait, does that mean she's also gaining value? Sounds like a good investment!
    Massey 1652 HSTC - TEREX PT70 CTL - Ford 550 Industrial TLB
    Hustler Z Diesel 66" ZTR - JD Gator 620i
    Stump Bucket * 60" Tine Bucket * 60" HD Grapple * 68" 4-in-1 Bucket * 72" GP Bucket * 72" Rock Bucket
    90" Hi-Cap Bucket * QA Forks * QA Tree-Puller * 96" HD BackBlade * 84" Dual-Grader * 84" BoxBlade * 84" Rake
    78" Disc * 72" LP Seeder * 3pt StumpGrinder * 3pt Chipper * 96" Ford Flail * ATI Pre-Seeder 805
  4. #24
    Join Date
    May 2006
    Posts
    127
    SW Michigan
    Mahindra 1538
    Just so that you folks are aware of the feeder that I'm loading. Opening is good for a 60" x 60" bale. Vet likes that fact that the hay is off the ground to lessen the chance of sand colic. I designed and built it last summer after seeing one from Klene Pipe on video.
    Attached Thumbnails Attached Thumbnails Wife tells me that we need a bigger tractor!-wp_20130902_009-jpg   Wife tells me that we need a bigger tractor!-wp_20130902_011-jpg
    Andrew Abrams
    Marcellus MI
    Mahindra 1538
    Mahindra 1538 backhoe
    60" Frontier tiller
    72" Frontier rear mower
    72" Mahindra brush cutter
    72" disc
    Ford PHD
    Land pride landscape rake
    Welco fork attachment
    Mahindra bale spear
    “Self is the opaque veil that hides the Face of God from us. It can be removed only in spiritual experience, never by mere instruction.”
    ― A.W. Tozer, The Pursuit of God
  5. #25
    Join Date
    Mar 2012
    Posts
    171
    West Grove, Pa
    Nice looking setup.
  6. #26
    Platinum Member tessiers's Avatar
    Join Date
    Sep 2007
    Posts
    728
    Central Maine
    05' JD 790 - 53' Ford NAA - 70' Massey Fergusen 135 diesel - 67' John Deere 3020 deisel - 77' John Deere 2130 - 1950 John Deere MC
    My next one is going to be a 5045 or 5055, gonna keep my 790 though. I do the same thing, trick I learned is you can curl more than you can lift, I roll the bale spear forward a little, lift the bale, then curl it back. It will gain you another foot or so on the front of the bale, at least it does for me. The other thing I have is a forklift mast that hooks into the backhoe sub frame, I can lift 1500 lbs. on the rear with no troubles at all. Cant dump or reach but it works well when its on the tractor. I just lift the bales between the forks and set them into the feeder. Trouble with that is I don't keep it mounted on the tractor most of the time. By the way I love your feeder, nice design and looks well built.
    check us out at www.tessiersfarm.com
  7. #27
    Veteran Member dieselcrawler's Avatar
    Join Date
    Jan 2008
    Posts
    2,446
    New Martinsville WV
    2013 JD 3005 2001 Kubota BX1800
    Wow... nice feeder. Any pix of it with a round bale in it? Great for horses... off the ground and covered. How meny horses do you feed with it? Looks like the sides fold down as the hay gets eaten, so they can get to all of it? We do our own squre bales, and with only 1 horse and 3 ponies its not too hard to keep up with. If we had more, and fed in the field I would steal your design in a heartbeat!
    Greg AKA DieselCrawler
    2013 JD 3005 4x4 w/loader, 530 squirrel power diesel, with gravity power-reverser
    2000-ish Kubota BX1800HST
    Trucks:
    1999 F250 Ext cab SB 4x4 7.3L diesel 6spd.
    2000 Excursion 4x4 7.3L diesel, wife's ride
    2002 F250 Ext Cab LB 4x4 7.3L diesel 6spd
    2000 F250 Crew Cab 4x4 gas/auto
    Project Extended Crew Cab SB, will get one of the 7.3/6spd drivetrains
    Redheaded wife, 7 kids, 5 horses/ponies, some cats, 4 dogs
    SEMPER PARATUS
  8. #28
    Elite Member
    Join Date
    Dec 2007
    Posts
    3,213
    texas
    7040 HDC 1153 fel
    you need a tractor along the lines of a 7060 kubota or any brand 70hp tractor.
  9. #29
    New Member
    Join Date
    Sep 2012
    Posts
    19
    Kennesaw, GA.
    Mahindra
    I have a Mahindra and like it. Is a 2816. It has been a real workhorse. It may also be cheaper but not sure for I have not compared the prices and other details. I use mine in construction not on a farm. Hope this helps.
  10. #30
    Elite Member wmonroe's Avatar
    Join Date
    Nov 2005
    Posts
    3,383
    Southwestern, PA
    1958 Ford 961 Powermaster
    Default
    Nice job on the feeder.
    Kubota L5240 with loader and backhoe
    1958 Ford 961 Powermaster LP
Similar Threads
  1. NEW T5. BLUE BLOOD TELLS.
    By ohio farmer04 in forum New Holland Buying/Pricing
    Last Post: 12-29-2012, 01:24 PM
  2. I really need a bigger tractor
    By Robert_in_NY in forum Rural Living
    Last Post: 02-16-2009, 07:10 PM
  3. K-mart tells a bunch of employees goodbye.
    By tposts in forum Related Topics
    Last Post: 01-06-2006, 07:42 PM
  4. Nematoda tells all
    By nematoda in forum Kubota Owning/Operating
    Last Post: 03-14-2002, 11:29 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
