Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 39
  1. #21
    Elite Member
    Advertiser
    MtnViewRanch's Avatar
    Join Date
    Mar 2005
    Posts
    9,423
    4000\' mountains of Southern California
    Mahindra 7520, Mahindra 3215HST, Case 580 extendahoe, Case 310 dozer, Parsons trencher, Cat D6,
    Default Re: Weight for control of implements
    Quote Originally Posted by bdog View Post
    Thanks. I am looking into what they will charge me if I buy the front and wheel weights.
    Cast iron is expensive. I know that I would not have what I have had I not have gotten a very good deal on all of it.
    Brian
    Top and Tilt Kits by Fit Rite Hydraulics
  2. #22
    Join Date
    Jan 2014
    Posts
    603
    S.E. MI
    JD 240, JD Z950A, JD 4115
    OP-
    I misssd it if you said-
    is your machine MFWD or 2 WD? If it's 2WD, I'd ask if I could try out the 4440 with your plow (it will actually pull a bigger one without problem) and then decide. They are excellent machines with well deserved reps.
  3. #23
    Veteran Member bdog's Avatar
    Join Date
    Mar 2004
    Posts
    2,041
    Texas
    John Deere 4440
    Quote Originally Posted by RG1 View Post
    OP-
    Mine is 2WD. 4440 is about 100 miles from me. No real way to try it out at my place. I know it will pull anything I need no problem. I have not used a 4440 but I used to own a 4430 which had slightly less HP.
    According to tractor data a 4440 has 46 more drawbar HP than I do. The 4440 operating weight is 13,270 lbs and if I fill the tires they hold almost 1000 lbs each.
    1980 John Deere 4440
    2006 John Deere 550 J dozer
    2016 John Deere 333E compact track loader
    2018 John Deere 35G excavator
  4. #24
    Join Date
    Mar 2004
    Posts
    2,041
    Texas
    John Deere 4440
    Well I checked on the prices of weights and spoke more with the guy with the 4440. I decided to get the 4440 and made a deal on it. So problem solved I guess. The 4440 had duals which I did not need and the dealer is taking them off and giving me a healthy credit for some implements so looks like all is well. The tractor has to be moved on a 18 wheeler so I am waiting on the scheduling to get that done but I should get it early next week.
  5. #25
    Join Date
    Jan 2014
    Posts
    603
    S.E. MI
    Sounds good. Post some pics here when you get it if you can. We all like looking at tractors.
    Here's something to watch until you get it and try it-
    http://www.youtube.com/watch?v=R97h3zj9MeE
    http://www.pinterest.com/pin/506162445590026117/
  6. #26
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    For plowing, loader weight is not all "good weight". The weight in front of the front axle will reduce the weight on the rear axle due to the "teeter-totter" effect of leverage. It's not a big deal on MFWD machines, but shows up readily with 2wd.
    If you have time and a few bucks, you can make cement wheel weights. Many tractor wheel centers have holes for bolt on weights. You can use long lag bolts, some plastic sheeting, plywood and create a cement weight that will add quite a lot of weight. You will be smart to include a couple hooks to allow the removal and replacement of the weights with a hoist, chain fall, or loader.
    On the trade, the older machine with 7700 hours is getting pretty long in the tooth. Depending on prior care, it could be waiting to fall apart or still run strong for 8000 more hours. The cost of extra weight on a known GOOD machine vs getting an unknown machine with lots of hours needs to be evaluated carefully. personally, I'd keep the "bird in hand".
  7. #27
    Join Date
    Mar 2004
    Posts
    2,041
    Texas
    John Deere 4440
    Here is a pic of it
    Attached Thumbnails Attached Thumbnails Weight for control of implements-44401-jpg
  8. #28
    Join Date
    Mar 2004
    Posts
    2,041
    Texas
    John Deere 4440
    And another.
    Thanks for the videos.
    Attached Thumbnails Attached Thumbnails Weight for control of implements-44402-jpg
  9. #29
    Join Date
    Mar 2004
    Posts
    2,041
    Texas
    John Deere 4440
    Quote Originally Posted by john_bud View Post
    That was definitely a concern. I know a lot of these tractors of this vintage farmers use daily still and they have 15,000 hours. Proper care is the key. This tractor is coming from a very reputable dealer who has been in business a long time. It was a trade in on a new tractor and the previous owner had it a long time 20 years I think. The dealer thoroughly checked it out and assures me all is good and I feel he will stand by it if not. Not necessarily a warranty but if it craps out the first week I have I am sure he will make it right. Being that I use my skid steer for all my loader work the tractor may only see 50-100 hours a year. A lot of these tractors might see that in a week and are likely doing a lot "harder" work than I plan to do with it. If it is solid when I get it I am sure it will last a long time doing what I plan to do with it.
  10. #30
    Elite Member
    Advertiser
    Join Date
    Mar 2005
    Posts
    9,423
    Just as an FYI, I would not of suggested weight in the loader bucket if I had known that it was a 2WD machine, sort of defeats the purpose of adding the weight. For whatever reason, I was under the impression that we were talking about a MFWA machine. My bad. And I believe that my 4x4 75HP tractor will pull better than the 95HP 2WD tractor. Very difficult to compare machines when they are completely different animals.
    Brian
Similar Threads
  1. Rear Blade Weight of Implements
    By olhillbilly in forum Attachments
    Last Post: 10-08-2011, 08:50 PM
  2. Whats with you guys and ballast boxes and rear weight implements.
    By Edward. S in forum John Deere Owning/Operating
    Last Post: 07-19-2011, 04:12 PM
  3. Weight of implements on 4110
    By tld in forum Attachments
    Last Post: 06-26-2010, 11:11 AM
  4. Weight of Tractors, Attachments, & Implements
    By Don R. in forum Kubota Owning/Operating
    Last Post: 11-09-2007, 09:50 AM
  5. Down/up control on pulled implements
    By hudr in forum Attachments
    Last Post: 10-11-2007, 10:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
