Results 1 to 9 of 9
  1. #1
    Gold Member
    Join Date
    Aug 2007
    Posts
    460
    Northern Illinois
    2013 Kioti dk40 hst, wright stander zero turn
    Default Backhoe teeth bent over
    The ground near Chicago is a little hard this time of year!Backhoe teeth bent over-image-jpgBackhoe teeth bent over-image-jpg
  2. #2
    Silver Member andrehoude123's Avatar
    Join Date
    Oct 2012
    Posts
    192
    Default
    Either that backhoe is real strong or that bucket was real used
  3. #3
    Super Member
    Join Date
    Sep 2000
    Posts
    6,595
    Default Re: Backhoe teeth bent over
    The teeth are NOT bent. The bucket cutting edge cracked at the weld seams and folded over.
    That's why you need to inspect your bucket! It can happen on a FEL bucket too.
  4. #4
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    No problem.
    >Clean it up,
    >Grind the crack to a "V" on both sides to get a 100% weld
    >Use a fresh pack of 7018 rod
    >And go at it!
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  5. #5
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,961
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Hammering the teeth into frozen soil or concrete will break the welds or break your hoe just about every time.
    Break out your cutting equipment and square up that mangled steel to remove all the old bottom plate material and weld, then put on a new bucket bottom and reinforced cutting lip. Weld it up with full penetration weld (weld from one side, then grind to solid metal from the other side and weld). The lip usually wraps around the side walls so what is left on yours, needs to come off and the whole thing replaced. You should be able to buy that cutting lip already pre-formed to the side bend.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  6. #6
    Gold Member
    Join Date
    Aug 2007
    Posts
    460
    Northern Illinois
    It's a rental machine, 600 hrs. Ditch witch makes nice machines. Never had this happen in 30 years. It was putting in house services, transformer to meter raceway.
  7. #7
    Elite Member GPintheMitten's Avatar
    Join Date
    Sep 2009
    Posts
    3,337
    Flushing, Michigan
    Kubota B2620 with BH65 backhoe, Ford 2N
    Did you get damage insurance? What did the rental company say?
  8. #8
    Gold Member
    Join Date
    Aug 2007
    Posts
    460
    Northern Illinois
    I'm not sure about the insurance. This happened to another line crew in our shop.
  9. #9
    Join Date
    Oct 2012
    Posts
    628
    Southern Utah
    John Deere 3120
    Quote Originally Posted by Illini22 View Post
    Bullet: dodged.
Similar Threads
  1. backhoe teeth
    By henrysMFGC2310TBL in forum Massey Ferguson Owning/Operating
    Last Post: 08-25-2011, 12:29 PM
  2. backhoe teeth
    By seedman4 in forum Customization
    Last Post: 12-17-2007, 08:43 PM
  3. Straightening bent BB teeth?
    By hsvhobbit in forum Attachments
    Last Post: 10-13-2006, 12:52 PM
  4. Bent teeth in tooth bar
    By Brad_Blazer in forum Customization
    Last Post: 07-19-2006, 08:20 AM
  5. Broke 6 of 7 Ripper teeth & bent rippers.
    By Cityboyfarmer in forum Attachments
    Last Post: 08-12-2005, 06:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
