Page 1 of 3 123 LastLast
Results 1 to 10 of 24
  1. #1
    New Member
    Join Date
    Dec 2013
    Posts
    22
    Vermont
    Deere 110TLB
    Default Wrong Chains?
    Living on a snowy mountain top we had chains put on our Deere 110TLB this Winter. But we are wondering if something is wrong with our new chains. The tractor doesn't seem to have much more traction than without them. This seems because most of the chains are below the treads on the Ag tires (see attached picture).
    Is it possible that: 1) these are the wrong chains?, the wrong size?, put on wrong?
    Thanks for any help.
    Attached Thumbnails Attached Thumbnails Wrong Chains?-tires-chains-jpg
  2. #2
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,712
    Foster, RI
    Mahindra 3016
    Default Re: Wrong Chains?
    Quote Originally Posted by mtputney View Post
    It could be because you have the chains too tight. Take off any side tensioners and see if traction improves. They also look a little small in the link size if I'm judging the picture correctly. They should be at least a 3/8" link for your size tire.
  3. #3
    Elite Member Gordon Gould's Avatar
    Join Date
    Apr 2007
    Posts
    3,604
    NorthEastern, VT
    Kubota L3010DT, Kubota M5640SUD, Dresser TD7G Dozer
    You are right - you are not gaining much there.
    You really need the chains to sit on top of the lugs like this H pattern chain set
    Wrong Chains?-tractor2-jpg
    Your picture doesn't show enough to see what changes you could make. They could be to long allowing the two main circumference chains to zig zag between the lugs instead of staying on top but need a bigger picture to tell much.
    "If you're not making any mistakes then you're not doing anything"
    M5640SUD, L3010DT, Farmi JL290 Winch, ATI Grapple, BearCat 5" Chipper, 6' & 7' Rear Blades, 7' Box Blade,
    7' Sickle Bar, 5' Land Plane Grading Scraper, Dresser TD7G Dozer
  4. #4
    Join Date
    Jan 2008
    Posts
    2,365
    Western PA
    John Deere 5083E MFWD, Kubota L3400 HST
    Loosen them up. I was running v-bar duo's like the picture of your chains (Same chain with ice cleats on them) and my R-1's would hide most of the links. My first solution was to increase the number of patterns on the tire. that didn't help much. It actually raised the heigh of the side chains and makes them walk a little bit. Next thing was I ditched the tensioners and only tighten the chains hand tight. It made a large difference. Actually you should have gotten some Aquiline talons of teffsdale tire chains. They have continuous loop of chain that rides across the tops of all the lugs. Hindsight is 20-20 though!
    '11 John Deere 5083E, 563NSL Loader, MX10 Mower, 78" Bucket, Forks/Bale spear (interchangeable)
    L3400 Kubota HST Loader, finish mower, rake, scraper blade, Gin pole, Kustom Fab front hydraulic snow plow (Inspired by ASGAR)
    JD 550 Dozer 6 way blade and winch
    JD 450B Track Loader
    Case 480C Backhoe W/ Extend-a-hoe
    '01 International 4700 LP, DT530, Allison MD3060, Air Ride, Crew Cab
    '11 Moritz 20+5 14.5K GN with adj. Tail
    ''08 700R Raptor
  5. #5
    Super Member crazyal's Avatar
    Join Date
    Dec 2003
    Posts
    7,010
    Northern Vermont
    Kubota, Case, Deere
    Short answer to your question is yes there are other styles that will not fall between the lugs. Try loosening them up. Just be careful not to do damage to your fenders.
    Kubota L4240,Case 580K backhoe, Case 450 Dozer, Deere X500
  6. #6
    Elite Member
    Join Date
    Dec 2002
    Posts
    4,712
    Foster, RI
    Mahindra 3016
    Loose chains mitigate the "falling between the lugs" syndrome almost completely. If one is on ice, this could present a small problem however if one is in the woods skidding, or in several inches of snow you will benefit with chains grabbing at first ground contact. I have the simplest chain (4 link ladder) on my ags with deeper thread than on a industrial. If you look at them, you think they'll do nothing as there they are between lugs on top of the tire. However the bottom is another story. They are loose with no tensioners and the chains make first contact. Every tire print in snow or soft dirt shows the indentation of the chain predominantly.
  7. #7
    Gold Member
    Join Date
    Dec 2012
    Posts
    273
    Grand Lake OK
    Kubota L4600
    Industrial tires not Ag looks like to me. R4 not R1
  8. #8
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    17,676
    Missouri
    Kubota M9540, Ford 3910FWD, Ford 555A, JD2210
    ENC, yep he's definitely running R4s.
    Loosen the chains all you can without them falling off. Then they'll squirm around more and stay out of the lugs. I'm guessing if you checked the side bars with them as in the picture, they would be extremely tight.
    I run 2-link straight crossbar chains on my Grader with Micheln Radials. If I install them as tight as I can they crawl between the lugs and lose efficiency. If I run them loose they work fine.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  9. #9
    New Member
    Join Date
    Dec 2013
    Posts
    22
    Vermont
    Deere 110TLB
    Thanks to everyone for the advice.
    Thankfully, the dealer agrees that the Tru-Grid chains are no good and will take them back.
    Will revisit this issue next Fall and make sure to order the correct chains for our R1 17.5 x 24.
  10. #10
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,151
    north idaho
    Kioti DK45SE hst cab
    go to http://www.tirechain.com/TractorChainmenu.htm and look at the 2 link ladder series. they will work on your tires just fine. I have R4's with them and traction is phenomenal .Wrong Chains?-_mg_5487-jpg
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
Similar Threads
  1. Car snow chains: regulars chains vs. cable chains
    By JD 4520 in forum Trailers & Transportation
    Last Post: 12-23-2012, 12:30 AM
  2. Chains: What's wrong with V-bar?
    By FatTire in forum Snow Removal
    Last Post: 08-07-2012, 08:00 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
