Results 1 to 9 of 9
  1. #1
    Join Date
    Sep 2013
    Posts
    946
    Riverside, CA
    Kioti CK27HST
    Default Color coding hoses to connectors
    My backhoe finally arrived at the dealer, but it still needs to be installed. So I don't have my tractor yet.
    But I went in to pick up my manuals and 'visit' my tractor, and was pleased to see they color code the loader hoses using colored zip ties to match (kinda) the connector caps!
    Color coding hoses to connectors-hoses_small-jpg
    Is this standard procedure? I'd never noticed it done before.
    Oh, and 'cause we all love pics - the backhoe still in plastic waiting to be installed:
    Color coding hoses to connectors-backhoe_small-jpg
  2. #2
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,676
    Nova Scotia, Canada
    Default Re: Color coding hoses to connectors
    Those coloured caps have a tendency to go walkabout. Consider a centre punch and leaving some permanent dots.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  3. #3
    Super Star Member ovrszd's Avatar
    Join Date
    May 2006
    Posts
    16,312
    Missouri
    Kubota M9540, Ford 3910FWD, JD2210
    Both of my tractors have color coded caps. When they finally give up, I'll add colored Zip Ties.
    Richard
    "Happiness isn't having everything you want, it's wanting everything you have."
  4. #4
    Elite Member
    Join Date
    Apr 2012
    Posts
    4,176
    Northern Ontario, Canada
    2012 Kioti CK27HST w/cab
    Mine has them too. Coloured zip ties is the way I will be going.
  5. #5
    Super Member grsthegreat's Avatar
    Join Date
    Jan 2011
    Posts
    7,034
    north idaho
    Kioti DK45SE hst cab
    you can get colored replacements pretty easily at hydraulic shops or on ebay
    all the tractors ive ever had have used them.
    currently own
    2011 Kioti DK45SE HST CAB tractor/loader, Jimna 6" - 3 point wood chipper, 60" JD Brush Hog, JD 60" Rototiller, 3 point post hole digger with hydraulic assist, 3 point spring tooth rake, Fimco 55 gallon weed sprayer with 12 foot boom, 3 point hydraulic wood splitter (home built)
    Quick Attach 79" loader mount snowblower & rear powerpack
    Quick Attach 84" Snow Blade
    Quick Attach 42" pallet forks
  6. #6
    Elite Member kebo's Avatar
    Join Date
    May 2006
    Posts
    2,857
    Lexington, SC
    2001 John Deere 790 4x4, bar tires
    I did a similar thing to mine. All the hose caps were black, but I put a different color of tie wrap on each paired end of the 4 hoses. The end result is life is good lol.
    Nothing could be finer than riding my JD790 in South Carolina!!
    2001 John Deere 790 4x4 with Model 70 FEL, 5ft International World Agritech bush hog, 5ft Wallberg BB, 5ft Frontier disc harrow, 5ft King Kutter II Rototiller, 5 1/2ft Cultipacker, 5ft Sitrex finish mower, Leinbach PHD with 9" & 12" augers, Leinbach middlebuster, Leinbach #11 Field Cultivator, custom 3pt handi-hitch, clamp on bucket forks, Pat's Easy Change.
    It's not how slow you mow... it's how well you mow slow!!
  7. #7
    Gold Member 600rider's Avatar
    Join Date
    Jul 2007
    Posts
    361
    union city pa
    2004 kubota b7510
    My loader valve came with colored rings on the hose ends to match the colored caps and I looked a little bit for more then I got some zip ties and they work great! It helps you "remember" witch hose goes with witch coupler!
  8. #8
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,377
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Don't overlook chicken banding rings.
  9. #9
    Join Date
    Sep 2013
    Posts
    946
    Riverside, CA
    Kioti CK27HST
    Quote Originally Posted by Leejohn View Post
    Never even knew those existed. Quick trip (via Google) to eBay and there's all kinds of them - sizes, colors, styles. Thanks!
    Just a sample:
    Color coding hoses to connectors-legbands-jpg
Similar Threads
  1. BX25 Color Codes for FEL Hoses?
    By Wingsy in forum Kubota Owning/Operating
    Last Post: 07-17-2013, 07:42 AM
  2. color coding of fuel cans, filler caps, and pumps???
    By hemiguy in forum Oil, Fuel & Lubricants
    Last Post: 02-28-2013, 09:18 PM
  3. Replies: 3
    Last Post: 08-31-2012, 10:48 PM
  4. [color:red] Just testing [/color]
    By Henro in forum Related Topics
    Last Post: 03-09-2004, 10:57 PM
  5. Coloring coding FEL hydraulic lines
    By nhman in forum Kubota Owning/Operating
    Last Post: 11-07-2001, 07:00 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
