Results 1 to 10 of 10
  1. #1
    b73
    b73 is online now
    New Member
    Join Date
    Feb 2014
    Posts
    19
    St.Tammany,la
    Ls4041H
    Default First 1/2day of work with the new Ls4041.Lots of questions.
    This is my first tractor and first time ever using one.Finished up the stumps I started on delivery day.Did some box blade work.Box blade on the driveway.Knocked down and dug up a few more trees.Only stopped because shes low on fuel and I haven't picked any up yet.First question is looking at the holes and size of stumps could I be working the new tractor to hard?I did chop the last bit of the larger stump with an axe to get it up but it lifted the back wheels many times and would go on to one front wheel a few times before I could let the loader down.Next question is when using the box I lowered it to the ground then lifted it about 1/4" is this correct? Also I've been keeping the rpm's around 1500 or so because its new then I read in the book to start the tractor at half throttle.Should i just run it like I stole it or keep a low rpm for a while? Oh yeah so far I love it(7hrs)and the extras you get as opposed to the 3038 I think are a big plus so far.But what do i know I've never used a tractor before.
    First 1/2day of work with the new Ls4041.Lots of questions.-dscn2229.jpgFirst 1/2day of work with the new Ls4041.Lots of questions.-dscn2230.jpgFirst 1/2day of work with the new Ls4041.Lots of questions.-dscn2234.jpgFirst 1/2day of work with the new Ls4041.Lots of questions.-dscn2231.jpgFirst 1/2day of work with the new Ls4041.Lots of questions.-dscn2232.jpgFirst 1/2day of work with the new Ls4041.Lots of questions.-dscn2233.jpg
  2. #2
    ENC
    ENC is offline
    Join Date
    Dec 2012
    Posts
    141
    Grand Lake OK
    Kubota L4600
    Default Re: First 1/2day of work with the new Ls4041.Lots of questions.
    If you are working or lugging the tractor give it more throttle. Doing what you describe I would be at about 2200 rpms. Stumps are hard jobs to tackle. On the safety side of things you definetly need more ballast weight. If you are lifting the tires up you can create a very dangerous situation very quick.
  3. #3
    b73
    b73 is online now
    New Member
    Join Date
    Feb 2014
    Posts
    19
    St.Tammany,la
    Ls4041H
    I put the box on today and that was way better than the cutter for ballast.My tires are not filled but I will fill them or have the dealer do it at 50 hr service.I want to build a 55 gallon drum ballast like one I've seen on here.The tires had to much air as well and letting some out seamed to help a little.The manual,as far as I've read,doesn't say anything about keeping rpm's down for break in so maybe I'll just let her rip next time.Hopefully tomorrow!!!
  4. #4
    Veteran Member GManBart's Avatar
    Join Date
    Dec 2012
    Posts
    2,248
    Belleville, MI
    Ford 8N, LS R4047H, Massey Ferguson 241, Hustler Sport ZTR
    Be very, very, very (did I say very?) careful pushing trees over with a tractor. If it's bigger than 8-10" at the base, it's probably not worth messing with.
    If you plan to do much digging, a tooth bar for the bucket makes a massive improvement in what you can get done. The teeth can also be used to carefully pry things up, or to tie off when lifting things that aren't super heavy.
    Advise is a verb!
    Never argue with an idiot. They will drag you down to their level, and beat you with experience!
  5. #5
    Super Star Member k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    12,786
    Branson, Mo.
    Kioti DK35se Hydrostat
    Hopefully you were frightened when the azz end of the tractor came off of the ground from lack of ballast on the 3pt. You should be, because it is dangerous. Remember the front axle is on a pivot bolt, there is no suspension when the rears com up the tractor is free to flop one way or the other, and if you are on an angle it can turn you over quick. You will get to have a nice look at the lower half of your tractor. NOT good.
    Adding ballast and loaded tires will make the tractors traction like a whole different tractor, much safer and much more push/shove/grunt. Of course with greatly increased traction now comes the possibility of tearing up the FEL, you have to use common sense. I know you want to get right in there and start using the machine, but going slow and learning as you go has some merit. Always think what will happen when you hook on to something, for instance if you hook a stump on the left front your right rear tire may raise in a heartbeat so keep you hand on the joystick and make small smooth movements.
    I can certainly remember some mistakes I made through the years, and really just got lucky. I have never turned one over, but sure came close several times It looks like you have mostly flat ground, and that is a BIG plus. Good luck and happy tractoring
    James KUA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner How to add a link to a post . Best way to search TBN
  6. #6
    Gold Member
    Join Date
    Dec 2013
    Posts
    328
    river falls, wi
    Kubota mx4700 HST, 2 Ford 8ns
    If you lifted the back end "many times" you should slow down a bit. That's a dangerous move, and should be avoided. Get the tires loaded and add ballast before proceeding carefully.
    Regarding the break in period. My kubota manual advises avoiding the same rpm for great lengths of time. Currently (still in break in period myself) I'll run a while at say 2000 rpm, then bump to 2100, then down to 1900. Also, I'm avoiding short durations of operation and avoiding idling for more than a minute or so.
    In short, I turn it on when I am going to use it for at least an hour. I warm it up around 1400, I use it well, not too hard, then cool down for a few minutes at 1400 before shut down.
    Good luck, be safe. Tractors are an inherently dangerous tool, most especially at the hands of new users.
    Kubota mx4700, Ford 8nx2, Timberking B-20 sawmill, Farmi 351 skidding winch, tiller, mower, bale chopper, etc. F250 5 speed I6. Stihl and shindaiwa saws.
    Every spring I drill 450 holes in maple trees, so I get to make about twelve cords of wood a year. Just me and the Gransfors Bruks splitting maul.
  7. #7
    b73
    b73 is online now
    New Member
    Join Date
    Feb 2014
    Posts
    19
    St.Tammany,la
    Ls4041H
    Thanks for the good info. Wouldn't have thought of not staying at same rpm for long. This thing will toss the wheels up in a hurry and I didn't realize the front axle was on a pivot but I never let it go very high.the few times I pushed a little and it was just right to put it up on 1 front wheel was definatly an eye opening,cheek clinching experiance. I started looking at the spades to clamp on fel or a stump bucket for all the trees I want to remove. Not sure if there worth it or not?
  8. #8
    Veteran Member vtsnowedin's Avatar
    Join Date
    Jul 2011
    Posts
    1,801
    What K0ua said and then some. Wheels off the ground is for cowboys with paid up Obama care. As soon as a wheel lifts, let off and try a different way. Get your rears loaded now, not fifty hours and a trip to the ER later.
  9. #9
    Platinum Member Red Horse's Avatar
    Join Date
    Dec 2010
    Posts
    701
    Bolton, MA
    Deere 655ZTrak, Deere 4720 Cab, 400 X
    Big 10-4 on getting your ballast NOW. Ballast the tires and build yourself a decent concrete weight block-plenty of good suggestions for doing that in these threads. Oh yeah-no one has mentioned seat belt use-buckle up! You have ROP but it only good if you are belted in.
    Last point, remember center of gravity goes up dramatically as you raise bucket-in particular with a load in it. Amazes me the yahoos you see running around looking UNDER the bucket for "better visibility".
    Take your time and get to know your machines capabilities
  10. #10
    TSO
    TSO is online now
    Veteran Member TSO's Avatar
    Join Date
    Apr 2012
    Posts
    1,540
    SouthEast Michigan
    Massey 1648 HST Cab
    Default
    Quote Originally Posted by b73 View Post
    <img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366875"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366877"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366882"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366879"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366880"/><img src="http://www.tractorbynet.com/forums/attachment.php?attachmentid=366881"/>
    Nice tractor and good pics. I lifted the tires up plenty of times when I had the R4041 & 4047. Like others have said, just be careful and throw some ballast on the rear.
    Massey 1648 HST Cab
    Previous: LS R4041/4047 & Kioti CK20S
    QA 72'' bucket * 60" Custom Grapple Bucket * QA Forks * 8' HD Back Blade * 84" HD Box Blade
    72'' Rake * WorkSaver SG-26 Stump Grinder * Middle buster plow * Wallenstein BX42s PTO Chipper
    Hustler Z Diesel 66" ZTR mower (25 hp Shibaura diesel)
    20' PJ Equipment Hauler/Trailer
    2008 F250 Crew V10 4x4
Similar Threads
  1. ideas for new saw: 20" type for lots of work
    By msukegrat in forum Chainsaws
    Last Post: 03-29-2011, 01:38 PM
  2. L2800 Has arrived 2day!
    By WV Tractorman in forum Kubota Owning/Operating
    Last Post: 10-15-2009, 10:42 PM
  3. new member lots of work
    By murfdog in forum Projects
    Last Post: 08-09-2009, 07:45 PM
  4. new here, lots of questions...
    By 5Minpins in forum Attachments
    Last Post: 08-12-2007, 07:45 PM
  5. Suggestions for small yard and lots of FEL work?
    By btb in forum Buying/Pricing/Comparisons
    Last Post: 04-14-2005, 11:31 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2013 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
