Can some of the ZTR pros chime in on whether they think this hill is to steep to mow with a Zero Turn. I am looking at a residential ZTR, like the 50inch Toro timecutter among a few other models. I have 3/4 of an acre so I don't need some commercial monster but would prefer to have ZTR over a tractor. Any insight is much appreciated! Picture of my hill below.
For 20 years, I cut with Dixie Choppers on hills like that, but usually only when dry.
I had a near fatal accident on one of the same hills, but wet. I made the mistake of turning down hill on a turn, and the machine lost traction, sliding down the wet hill in full reverse. At the bottom of the hill was a 4 ft drop off, and I dove off the Chopper as it went over, but it still fell on top of me.
I also had 25 lbs of extra weight on the front.
On some hills, I could go straight up and down, using bar tires.
Other times I did a 45 degree cut until I had cut the hill.
If the hill is firm you might be able to cut side across the hill, but try and turn up hill wet or dry.
If the hill is not firm, you will probably slide some,
After cutting that hill for a while, you will find the best way.
Some of the Z turns have front brakes.
