Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 40
  1. #11
    Super Member 5030's Avatar
    Join Date
    Feb 2003
    Posts
    6,000
    Michigan, S.E. Monroe County
    Kubota M9000 Hyd Kubota M105 shuttle
    Default Re: This is how I fuel the tractor
    Quote Originally Posted by Poopdeck Pappy View Post
    I use the No-Spill can. I lift it up on the loader arm. Then I stand on top of the front tire. I let the base of the No-Spill rest on the loader arm, and lay the No-Spill down and push the button. Pretty simple stuff and the No-Spill doesn't leak a drop.
    I've got this 50 gallon diesel tank with a toolbox on top mounted in my utility trailer. But I usually don't have the trailer with me at the property, so I just use the No-Spill can these days.
    Hope ypu are aware that the length of galvanized pipe in your fuel delivery system will eventually cause you issues...... Diesel has a bad habit of pullinbg the galvanizing from the ID of the pipe (in solution) and depositing it at your injector tips, eventually destrpying the injector.
    You need black pipe, not Galv.
    A couple Kubota's and some payment books.....
    "If haying was easy, everyone would do it. It isn't."
  2. #12
    Veteran Member orezok's Avatar
    Join Date
    Jan 2004
    Posts
    1,655
    Mojave Desert, CA
    Kubota B7800
    A couple of galv fitting probable isn't a problem but NFPA sez...
    "NFPA-30 gives further recommendations on use of UL listed tanks, vent piping and vent capacity, tank openings, and drainage. Reactive metals such as galvanized steel , zinc, and copper should not be used in fuel system construction as these types of metals can serve as an oxidation catalyst with diesel fuel."
    Fuel oxidation is one of the primary contributors to poor fuel.
    Mojave - it's not the end of the world, but you can see it from here!
  3. #13
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,803
    Nova Scotia, Canada
    Quote Originally Posted by oldballs View Post
    Next to my shed, I have a 5 foot stand (in the shade of cedar trees) that I lift the 5 gallon jugs on to. Then I throw a siphon hose over a branch and take a break on the tractor seat while it fills. Works for me as a poor boy way of doing things. Using some junk lumber and eight feet of 5/8 inch tubing, it didn't cost much. You gotta have some good lungs to get it going . Yet those full jugs are a little heavy for me to get up to 5 feet.......as I'm only 5'3'' myself....guess I've got more brawn than brains.
    Put your finger over the end of the siphon tube ald lower almost all the tube to below the level of fuel inthe tank. Slowly pull out tube to fuel tank and release finger. Fuel should flow. There are othe ways of doing this and not having to use your finger.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
  4. #14
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,998
    Kansas...USA
    Kubota B2620 , Case 448 , Kubota B2650
    Thanks, Egon....will have to try that if, for no other reason, to prove that it works.
    Kubota B2620 (2012) Case 448(1983) Kubota B2650 (2018)
  5. #15
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    if you can lift the 5 gallons of fuel to the hood.... this is what generally gets used here.
    American Wick® Hand Operated Siphon Pump (SI-60) - Kerosene Heater Accessories - Ace Hardware
    This is how I fuel the tractor-pace-963674dt-jpg
    your more likely to find these at winter time for keresone heaters at most of the larger hardware stores, and possibly during spring/fall at farm stores.
    Ryan
  6. #16
    Elite Member Poopdeck Pappy's Avatar
    Join Date
    May 2013
    Posts
    2,568
    Dallas, Texas
    Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
    Quote Originally Posted by 5030 View Post
    Hmmm. Are you talking about the pipe and fittings between the filter and the pump?
    Didn't know that, but those pieces would be simple to replace.
    __________________
    Pappy
  7. #17
    Veteran Member KiotiKowboy's Avatar
    Join Date
    Apr 2014
    Posts
    2,234
    Northeastern Oklahoma
    Kioti DK50SE HST Cub Cadet UTV Swisher RC17552BS NRA_Life
  8. #18
    Silver Member TBarD's Avatar
    Join Date
    Mar 2012
    Posts
    180
    Rural mountains, SW Colorado (also NM)
    Kubota M59
    I have the exact same toolbox / transfer tank in the back of my truck, that I use to fuel both truck and tractor using 12v off the truck (this allows for lubricity, Cetane etc. additives for both, and use of a prefilter, and gives me a 1000 mile range when towing heavy as well as a convenient way to top off the tractor). However I will need to look into the galvanized pipe issue to see what I have - first I have heard of this problem.
    Kubota M59 TLB w/thumb, Bradco forks, Befco 84" grading scraper, McMillen 3K2 hydraulic auger, CA 8' boom, hay forks
    CA 80" 4n1 bucket, Bison 84" Box blade w hyd scarifiers, Anbo Rancher grapple, Befco 6' brush hog
    Ram 5.9L, PJ 22' 14K trailer, PJ 16' 16K dump trailer, Hobart 250amp MIG welder
  9. #19
    Join Date
    Aug 2001
    Posts
    20,803
    Nova Scotia, Canada
    To fill my tractor I prefer to drive in to the local service station and just use the pump.
    Egon
    Livin in a
  10. #20
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,903
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Quote Originally Posted by kco View Post
    I use a similar tank and pump system, Gary, but with a booster pack similar to this:
    Motomaster Eliminator 800A Powerbox | Canadian Tire
    The booster pack is handy for trips to the back country and for lighting and small appliances during power outages.
    I think my tank is 70 imperial gallons(318 liters):
    Attachment 384956
    I fill it two or three times per year. It is easy to transport in the truck.
    A booster pack is what I was using till the battery quit taking a charge. It wasn't as big as the one you linked but the same principle. It doesn't take much juice to run the pump to fill a 10 gallon tank but one of my tractors now hold 26 gallons so it takes about twice as long. Still these little pumps can run a long time on a super small battery. I tore mine apart when it quit taking a charge and turned it into a battery minder.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
Similar Threads
  1. How do you fuel your tractor?
    By Dano33 in forum John Deere Owning/Operating
    Last Post: 06-04-2014, 05:46 PM
  2. Oil & Fuel Tractor gasping for fuel ?
    By BobG116 in forum Kubota Owning/Operating
    Last Post: 05-20-2013, 01:21 PM
  3. Got the fuel container spout out of tractor fuel tank
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 05-29-2012, 06:43 AM
  4. Propane as Tractor fuel
    By jaquetarr in forum Oil, Fuel & Lubricants
    Last Post: 11-04-2009, 08:22 AM
  5. Oil & Fuel Fuel Cell Tractor
    By fluffyone in forum New Holland Owning/Operating
    Last Post: 04-10-2009, 09:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
