Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
  1. #1
    Epic Contributor k0ua's Avatar
    Join Date
    Jun 2009
    Posts
    27,454
    Branson, Mo.
    Kioti DK35se Hydrostat
    Default This is how I fuel the tractor
    There have been many threads on fueling the tractor, and I thought I would just show how a 59 year old office worker fuels his tractor 5 gallons at a time.
    I have the older Blitz 5 gallon diesel fuel cans with the 2nd generation lever control valve. I did yank out the safety lock "guts" of the valve as that is just stupid to have to push a slide lever then the main lever to start the fuel flow, and if you let up on the main lever the safety lock must be actuated again. So a pair of needle nose pliers and one good yank is all it takes.
    Here is what I do, I lay a soft towel on the hood after blowing away any loose dust. and remove the fuel cap. then lift the can to the Right front tire, then lift again to balance on the loader arm, and then lift over and tilt the can to lay on its face on the towel on the hood with the spout sticking right in the fuel filler neck. Then just hold the fuel can lever down with your thumb and watch it gurgle in. There is no holding of a heavy can, just lifting for a couple of seconds, and the final lift is slight downward, and using two hands on both the top and rear handle of the jug, so it is pretty easy to do.
    As I pointed out I am not very strong, or at least no where near the strength I had 30 years ago when I did more physical work. So I would think most anyone could do this. I hope this helps someone
    This is how I fuel the tractor-img_20140802_113911_610-jpgThis is how I fuel the tractor-img_20140802_113916_111-jpgThis is how I fuel the tractor-img_20140802_113938_378-jpgThis is how I fuel the tractor-img_20140802_114028_205-jpg
    James K0UA
    Kioti DK35se hydrostat with 2 QA buckets, 48 inch. King Kutter Rotary Cutter. 750 lbs ballast box. Loaded tires, Construction Attachments SSQA Lightweight Pallet forks. EA 50 inch single lid "wicked" Grapple. Satisfied Everlast PA160 welder owner NRA Life Member How to add a link to a post . Best way to search TBN .
  2. #2
    Silver Member VitaBene's Avatar
    Join Date
    Oct 2009
    Posts
    207
    Moultonborough, NH
    Kubota L3430
    Default Re: This is how I fuel the tractor
    Quote Originally Posted by k0ua View Post
    I do essentially the same (especially the towel part!!)
    L3430HSTC w/ LA723 loader, Woods RD7200 finish mower and Kubota L2174A front mount snowblower
  3. #3
    Super Member newbury's Avatar
    Join Date
    Jan 2009
    Posts
    8,792
    From Vt, in Va, retiring to MS
    Kubota's - B7610, M4700
    I generally just put the 5 gallon jug on the hood and then use a clear plastic tube about 6' long to siphon it in.
    My rides - '95 Kubota M4700 w/ PEC, LA1001 FEL :'07 B7610, LA352 FEL, Bush Hog SBX 48 box blade, '09 Woods BH70-X w/ 16" bucket and thumb, 3pt pallet forks, Dale Phillips PHD, Jinma 8" chipper, 2 Piranha's, Winco 12KW PTO generator, Howse plow, 5' KK tiller, 5' Big Bee cutter, with a 2002 7.3L Ford F350 CC DRW 4x4 and '07 18' Hudson HSE Deluxe trailer - 5 Ton to haul it all
    My saws - 12" B&D 40 volt,JD CS 62, efco 3500, Stihls - 021, 660 w/woods mod, 660 w/ DP muffler, 088, Woodmizer LT10
  4. #4
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,717
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    It didn't take me long to find out that lifting a 5 gallon can overhead to set on the hood was a bit of a strain. Setting it on the wheel then meant I had to stand on the foot board with one foot and the other on part of the FEL or stretch out and put the other foot on the front tire which could be slick from mud or wet which was prone to slipping.
    I found a 100 gallon tank with 12Volt 15 GPM pump with 20 foot of hose for $300 and it has worked for me for 5 years now. I used a little jumper battery for a while till it went bad then just put a small car battery with a battery maintainer to keep it charged. It works for me and not lifting or hauling of 5 gallon cans of fuel.
    I wish gasoline would remain fresh long enough to justify home bulk storage but even 10-12 gallons is starting to get stale (by this I mean changing from clear to amber color) by the time I use it up.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  5. #5
    Silver Member DB Pilot's Avatar
    Join Date
    Feb 2013
    Posts
    243
    SW, New York
    David Brown 780 Selectomatic, L3800 Kubota, BX2200 Kubota
    That is pretty close to my method. I put the towel or place a board across the FEL arms and set the 6 gallon plastic antique Chilton fuel can on that. Then I have a plastic siphon and when that stops I just have about 1/2 gallon of fuel left which is easy to pour into another tractor with a funnel.
    K0ua I have tried pumps and of course the hold and balance the fuel can method. But with our method I have not spilled any fuel. So it is cost effective for sure. I have wasted fuel with the new spill proof government regulated gas cans. Of course that is probably my fault for being raised with common sense instead of common core.
  6. #6
    Join Date
    Jun 2009
    Posts
    27,454
    Branson, Mo.
    The overhead tank would be ideal, but my method does not cost much. Of course the size of the tractor would factor in to whether my method would work for you or not. I am standing on the ground at all times during this, so there is no danger. A taller tractor could be a different story. I don't have any trouble at all with the lifting, as I don't have to "hold" any weight. But if I get to the point I cannot lift the can to the hood any longer, I guess I could either give it up or buy the bulk storage tank.
    James K0UA
  7. #7
    Join Date
    Jun 2009
    Posts
    27,454
    Branson, Mo.
    Quote Originally Posted by DB Pilot View Post
    Yes, I have never spilled any fuel either, or had any trouble with this method. Some of the new spouts do not look very appetizing from what I have seen, so I am not sure what I am going to do when these two wear out.
    James K0UA
  8. #8
    Join Date
    Jun 2004
    Posts
    1,084
    Armstrong, BC
    Kioti DK35 SE HST (2011)
    Quote Originally Posted by Gary Fowler View Post
    I use a similar tank and pump system, Gary, but with a booster pack similar to this:
    Motomaster Eliminator 800A Powerbox | Canadian Tire
    The booster pack is handy for trips to the back country and for lighting and small appliances during power outages.
    I think my tank is 70 imperial gallons(318 liters):
    This is how I fuel the tractor-20130531_tidytank_1-jpg
    I fill it two or three times per year. It is easy to transport in the truck.
    Attached Thumbnails Attached Thumbnails This is how I fuel the tractor-20130531_tidytank_2-jpg
  9. #9
    Elite Member Poopdeck Pappy's Avatar
    Join Date
    May 2013
    Posts
    2,568
    Dallas, Texas
    Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
    I use the No-Spill can. I lift it up on the loader arm. Then I stand on top of the front tire. I let the base of the No-Spill rest on the loader arm, and lay the No-Spill down and push the button. Pretty simple stuff and the No-Spill doesn't leak a drop.
    I've got this 50 gallon diesel tank with a toolbox on top mounted in my utility trailer. But I usually don't have the trailer with me at the property, so I just use the No-Spill can these days.
    __________________
    Pappy
  10. #10
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Posts
    2,875
    Kansas...USA
    Kubota B2620 , Case 448
    Next to my shed, I have a 5 foot stand (in the shade of cedar trees) that I lift the 5 gallon jugs on to. Then I throw a siphon hose over a branch and take a break on the tractor seat while it fills. Works for me as a poor boy way of doing things. Using some junk lumber and eight feet of 5/8 inch tubing, it didn't cost much. You gotta have some good lungs to get it going . Yet those full jugs are a little heavy for me to get up to 5 feet.......as I'm only 5'3'' myself....guess I've got more brawn than brains.
    Kubota B2620 HST (2012) Case 448(1983)
Similar Threads
  1. How do you fuel your tractor?
    By Dano33 in forum John Deere Owning/Operating
    Last Post: 06-04-2014, 06:46 PM
  2. Oil & Fuel Tractor gasping for fuel ?
    By BobG116 in forum Kubota Owning/Operating
    Last Post: 05-20-2013, 02:21 PM
  3. Got the fuel container spout out of tractor fuel tank
    By JOHNTHOMAS in forum Kubota Owning/Operating
    Last Post: 05-29-2012, 07:43 AM
  4. Propane as Tractor fuel
    By jaquetarr in forum Oil, Fuel & Lubricants
    Last Post: 11-04-2009, 09:22 AM
  5. Oil & Fuel Fuel Cell Tractor
    By fluffyone in forum New Holland Owning/Operating
    Last Post: 04-10-2009, 10:25 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
