Page 1 of 2 12 LastLast
Results 1 to 10 of 13
  1. #1
    New Member
    Join Date
    Aug 2014
    Posts
    4
    Norwich, OH
    John Deere 1023 E
    Default 1023 E
    Anybody out there having any luck mowing with a 1023 E?
  2. #2
    Elite Member Piston's Avatar
    Join Date
    Sep 2008
    Posts
    3,679
    Lakes Region NH
    Kubota L4610 Hitachi UH083LC
    Default
    Karen, welcome to the forum!
    Can you explain a little more about your question? What do you want to know? Do you have one and are having problems with the quality of cut? Are you looking to buy one as your primary mowing machine? Do you want golf course quality manicured lawn?
  3. #3
    Platinum Member chevy's Avatar
    Join Date
    Mar 2003
    Posts
    627
    East Central, Indiana
    John Deere 4120 John Deere 1026R
    Default Re: 1023 E
    I have a dressed up version of the 1023E, a 1026R & have over 100 hours mowing with it. I have not had any problems so far.
    What issues are you having?
    John Deere 2025R, H130 Loader, 62D Mower Deck, John Deere 655 Tiller, Front Grader Blade, Frontier LR2072 Landscape Rake, Frontier Pallet Forks, Woods GB60 Box Blade
    John Deere X739 AWS 4x4 with 60HC deck.
    John Deere 825i Gator
    John Deere Tractors I have owned in the past.
    425 AWS, 455, 4400, 2210, 4710, 2320, 2720, X475, 1026R, 4120
  4. #4
    New Member
    Join Date
    Aug 2014
    Posts
    4
    Norwich, OH
    John Deere 1023 E
    Default Re: 1023 E
    Quote Originally Posted by Karen Boehm View Post
    Our 1023E mowed a large groove in our yard when it was delivered. After 2 hours of work my husband had it working better (he is a mechanic), but wasn't very satisfied as it still scalped a lot. We took it back to the dealership where they acted like we were totally stupid (we have never mowed with anything but a JD) and we own a 2210 which was what we were hoping to replace with the 1023 as it had lots of mowing hours. On the 2210 you could remove the ROPS by removing a few bolts this one is not easy and mowing around trees or anything else is pretty much impossible. When you back up the mower deck shuts down and then the engine shuts down unless you pull up on the PTO switch BEFORE you back up, in other words it may be safe, but it SURE isn't much to mow with. The tractor shuts down when I turn my head to back up (it has been suggested by my friends that I may need a cement block on the seat beside me) which is an annoyance to say the least. We bought the 1023 as we were told that the loader and mower deck from the 2210 would not work on the the 2035, which we are also told is false by a JD dealer in Cincy. In a nut shell the 1023 has been a TOTAL nightmare. Any suggestions?
  5. #5
    Super Member s219's Avatar
    Join Date
    Dec 2011
    Posts
    6,470
    Virginia USA
    Kubota L3200 Deere X380 Kubota RTV-X
    Default Re: 1023 E
    The safety items are standard nowadays, such as needing to pull lever when going into reverse mowing. So you'll need to accept that if you want a modern mower. ROPS should be fairly easy to fold, but is not intended to be removed. The seat switch might be too sensitive and need adjusting, or maybe you don't realize you're lifting off the seat, but again that is a standard safety item on modern mowers. Even my large tractor will cut engine if I rise off seat while moving.
    The dealer can fix anything thats broke, but it sounds like your main beef is with all the safety features.
  6. #6
    Elite Member Poopdeck Pappy's Avatar
    Join Date
    May 2013
    Posts
    2,568
    Dallas, Texas
    Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
    Default Re: 1023 E
    You WILL get used to pulling up on the PTO switch before you back up. It takes a little time, but it will become second nature. If it's like the older ones, you don't have to keep it pulled up as you back up. Just pull it up when you start backing up, and the mower will keep running unless you let off the reverse pedal and then press the reverse pedal again.
    There's probably an adjustment on the seat switch that can be made to keep it from shutting down when you move slightly. Either that or you could gain a whole bunch of weight and that would help keep the switch pressed. Ok, that last one was probably a bad idea.
    __________________
    Pappy
  7. #7
    New Member
    Join Date
    Aug 2014
    Posts
    4
    Norwich, OH
    John Deere 1023 E
    Default Re: 1023 E
    You are right some of my beefs are with all of the safety stuff that makes it impossible to use as a mower. I also can't figure out why ANY dealer would send a 1023 out that wasn't set up to mow. It mowed big grooves in our yard. It seems like this easy attach mower is not like other JD mowers other JD mowers are floating units that do a better job on uneven ground, this mower is attached differently and doesn't appear to float.
    The hood on the 1023 E is not right either and the dealership says there is nothing they can do to fix it. It either has a gap on the right side or a gap on the left side or is even on both sides of the hood but the hood does not cover the lip of the tractor. Anyone had any issues like that with the hood?
  8. #8
    Elite Member KennyG's Avatar
    Join Date
    Jan 2011
    Posts
    2,513
    SW Michigan
    John Deere 2320
    Default Re: 1023 E
    I know the 1023 has the autoconnect deck so it may be different from the earlier models, but my 2320/62D combination attaches with two lift arms. It's meant to be adjusted such that the gauge wheels are just off the ground when on level surfaces. Does that seem to describe yours?
    If so, the mower height range is controlled by the lift arm adjustments which should be set such that the deck almost touches the frame when fully raised. A number of us found that the dealers did not set them high enough and we couldn't get a decent cut height. After adjusting the arms all is good.
    Mine is early enough it does not have the reverse switch. If it had one it would be gone by now. Relative to the seat switch, I had trouble initially because, as an old timer, I was used to standing up on the tractor while operating it. I have since retrained myself and don't have a problem. However, since you are probably smaller and lighter than me you may want to look at adjustments to the switch.
  9. #9
    New Member
    Join Date
    Aug 2014
    Posts
    4
    Norwich, OH
    John Deere 1023 E
    Default Re: 1023 E
    Thanks for all of your help/suggestions, as for the technical aspects of how the mower is mounted that is a question for hubby, will see what he says. We have worked to get the deck to mow at the height that we want and I think that is ok now. The ROPS prevent us from mowing close to trees, we mow a lot and have quite a few trees and it now takes twice as long (or even more) to mow around the trees with a push mower. Safe is ok, but sure not helpful in getting the mowing done.
  10. #10
    Elite Member Dutch445's Avatar
    Join Date
    Aug 2001
    Posts
    2,618
    Upstate NY
    JD X585
    Default Re: 1023 E
    just a quick comment on the implements, your old implements will not fit the new tractor, totally a different loader mount and mower mount/lift system.
    are you folding the ROPS down to mow with? if so is it still too high?
    the mower deck still hangs from the tractor, if you are getting scalping make sure your gage wheels are
    just off the ground 1/4 -1/2 inch, or less if you want a more consistent cut. where is your mower deck
    scalping?
    JD X585 with 45 loader, 3ph, 62C deck, 47SB, 54 blade, Soft Cab. JD F620 with 60". JD HPX gator. JD T23 trimmer
    JD CS56 and CS36 saws. JS35 WB mower.
Similar Threads
  1. 1026 seat on a 1023
    By SI2305 in forum John Deere Owning/Operating
    Last Post: 05-20-2013, 02:56 AM
  2. 1023/1026 a good choice?
    By s219 in forum John Deere Buying/Pricing
    Last Post: 12-09-2011, 03:38 PM
  3. 1023 Turning radius
    By Kiteflyer in forum John Deere Owning/Operating
    Last Post: 08-27-2011, 07:09 PM
  4. 1023 spotted and inspected
    By megotatractor in forum John Deere Buying/Pricing
    Last Post: 07-23-2011, 12:47 PM
  5. MF 1023 deck (belt )
    By doc19691969 in forum Massey Ferguson Owning/Operating
    Last Post: 05-20-2004, 01:22 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
