Page 3 of 3 FirstFirst 123
Results 21 to 24 of 24
  1. #21
    Elite Member Poopdeck Pappy's Avatar
    Join Date
    May 2013
    Posts
    2,568
    Dallas, Texas
    Kioti DK50SE Cab, Kubota BX23, Kubota BX2660, Grasshopper 729BT
    Default Re: Boom Pole ?
    Just remember that you can lift a lot of weight with a fulcrum if it's long enough.
    So, think of that boom pole attached to your FEL as a fulcrum trying to lift the rear end of your tractor off the ground. When you add weight to the end of the boom pole, it might not take a lot to lever the rear end off the ground.
    __________________
    Pappy
  2. #22
    Elite Member
    Join Date
    Sep 2007
    Posts
    3,430
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Well tried the 12', could lift it with the boom ok but couldn't curl. Almost would do it, I think if the hyd relief valve was set a 100psi higher it would of done it. So it looks like I well have to use the 8' to put it up on the deck then hook the 12' to go the rest of the way up. Then I well be lifting only 1/2 the weight and pushing the rest of the way up.
    The last picture is a bucket I picked up for $160.00 and making some changes to it for when it's time to go get fire wood.
    Lee
    Attached Thumbnails Attached Thumbnails Boom Pole ?-013-jpg   Boom Pole ?-008-jpg   Boom Pole ?-007-jpg   Boom Pole ?-006-jpg   Boom Pole ?-003-jpg
    Boom Pole ?-002-jpg
  3. #23
    Super Member Xfaxman's Avatar
    Join Date
    Feb 2013
    Posts
    7,989
    Meridian, OK
    Bobcat V417 Toolcat 5610 G TORO+Loader
    Need pictures of what you are building, please.
    Hold "Ctrl" (Control) and click on a picture or a Link, to open it in a new Tab.
    My Avatar, the TORO+Loader:
    Kwik-Way FEL and TORO Groundsmaster Put Together
    V417 Compact Telehandler: ​(This replaced my tractor): The best machine to do what I need a machine to do
  4. #24
    Epic Contributor
    Join Date
    May 2004
    Posts
    26,985
    Northeast Ohio
    Kubota B2910, Simplicity 18 CFC, Cub Cadet 782
    Quote Originally Posted by Leejohn View Post
    Looks like a nice score on the bucket ...
    "If liberty means anything at all, it means the right to tell people what they do not want to hear."
    "The real division is not between conservatives and revolutionaries but between authoritarians and libertarians."
    "If you want a picture of the future, imagine a boot stamping on a human face - for ever."
    - Eric Arthur Blair, otherwise known as George Orwell
Similar Threads
  1. Boom Pole for SS
    By Todd727 in forum Build-It Yourself
    Last Post: 09-12-2012, 07:12 AM
  2. FEL Gin pole (Boom pole and then some)
    By srjones in forum Build-It Yourself
    Last Post: 04-04-2006, 03:30 AM
  3. Boom pole or gin pole( with hydrolic cylinder)
    By dennis001us in forum Customization
    Last Post: 01-07-2006, 02:15 PM
  4. Boom Pole
    By bill18163 in forum Attachments
    Last Post: 10-29-2003, 08:33 PM
  5. Boom Pole
    By MikePA in forum Attachments
    Last Post: 05-27-2002, 07:52 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
