Page 1 of 2 12 LastLast
Results 1 to 10 of 14
  1. #1
    New Member
    Join Date
    Aug 2014
    Posts
    3
    streetman , texas
    kubota 7040
    Default kubota 7040 and 12' landpride RC 2512 leaving streaks
    hello
    I have a new kubota and I purchased the landpride RC 2512, with the rpms running at 540 rpm , sometimes there are streaks of uncut grass , Is there something that I can do to correct this issue .
    thanks
  2. #2
    Gold Member moriboy's Avatar
    Join Date
    Jul 2010
    Posts
    340
    SW Oregon
    Kubota M7040, L3901, KX057-4, JD 650G
    Default Re: kubota 7040 and 12' landpride RC 2512 leaving streaks
    I run into this issue sometimes if the grass is really long. The tires on the tractor mash the grass down and the mower misses it....
  3. #3
    Elite Member
    Join Date
    Feb 2011
    Posts
    3,826
    Trivoli, IL
    SSTT (Sideways Snake Tain Tractor) and STB (sideways train box) tractor, dirt harvester
    rotatory cutters and cutting tall weeds and stuff are completely different than finishing mowers that you use when mowing your lawn. rotatory cutters rough cut. if ya wanting a finishing mower look, then get out there much more often and keep the stuff from getting to tall. but kinda defeats idea of mowing 2 to 3 times a year of the pasture. vs finishing mower the lawn were ya out there approx once a week mowing.
    Ryan
  4. #4
    Join Date
    Jan 2007
    Posts
    1,419
    Creal Springs, IL
    Kubota M7040, F3680, Mule Pro Fxt
    I have an M7040, and lately I've been thinking of getting a 12ft bat wing, perhaps landpride....so interested in more information.
    I would wonder at what height you have the mower? And what type weeds grasses are you cutting? What gear are you running the M7040 in?
  5. #5
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    As moriboy states, the problem is most likely tires pressing down the foliage and missing being fully cut. Then the next day or two it stands up again and looks like crap.
    The only solution is to go over the area again and miss the tall foliage with your tires.
    A photo of the problem would go a long way for us to help you solve the issue.
    Another possibility is that when mowing very thick and heavy weeds (or brush) the blades of a rotary cutter will swing back and out of the way. The only solution to that is to travel much slower in the heavy areas.
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  6. #6
    Member
    Join Date
    Apr 2013
    Posts
    40
    N/A
    Kubota L38
    Quote Originally Posted by davtreece31 View Post
    hello
    thanks
    Have you tried cutting in reverse over an area you have not previously driven over? As others have stated the issue is most likely the taller grass you're flattening out with the tires. If you're cutting it regularly, you will need to cut it sooner when it is not as long. I have the same issue with a 5' cutter on a smaller machine and it requires me to overlap passes. The issue would be less pronounced if your left deck spun clockwise and your right deck CCW (assuming the retreating sides would be cutting over the tire tracks). The retreating side of the deck does a better cut of flattened grass. Cutting perpendicular to your last cut also helps alleviate the issue somewhat.
  7. #7
    New Member
    Join Date
    Aug 2014
    Posts
    3
    streetman , texas
    kubota 7040
    thanks for allf the help I agree that it is probably the tires but the goat weeds are tough to mow anyway !!! is there a alternative type of cutting blades for the landpride ?
  8. #8
    New Member
    Join Date
    Aug 2014
    Posts
    3
    streetman , texas
    kubota 7040
    Is there a optional set of blades on the market that may provide a better cut for thicker or tougher grass?
  9. #9
    Member
    Join Date
    Apr 2013
    Posts
    40
    N/A
    Kubota L38
    If you're using it for general mowing and not going to be doing any brush/sapling mowing, sharpen the blades! Sharp blades cut grass better while dull blades hold up a little better to abuse. Dull blades also tend to shatter sapling trunks to avoid having solid stubs left behind.
  10. #10
    Join Date
    Jul 2009
    Posts
    3,000
    Northern CA
    I don't think that you'll get any better results with a different style of blade. If the tires are matting down the weeds then blades of whatever style will miss them.
    Some smaller mowers have "high lift" blades that are supposed to create a vacuum to lift the grass but I haven't seen them for a Bush Hog style mower.
    I'll say it again, the best method is to re-mow over the high spots in a couple of days. Of course, if the area is 100 acres, or so, and you are charging for the mowing then that option is less desirable.
    Mowing 90 to the original path is not the greatest either. That will leave tire-width square patches over the entire field. Been there, done that (only once).
Similar Threads
  1. Kubota 7040
    By JD3520Cab in forum Kubota Owning/Operating
    Last Post: 04-02-2012, 09:16 AM
  2. JD 4720; considering leaving Kubota
    By ecoscaper in forum John Deere Buying/Pricing
    Last Post: 12-04-2010, 08:55 PM
  3. Price Check 04 Kubota M6800 w/Cab and bush hog 2512
    By mxjoubert in forum Buying/Pricing/Comparisons
    Last Post: 08-21-2010, 04:59 PM
  4. Black Streaks-RV
    By grainger12002 in forum Related Topics
    Last Post: 12-10-2005, 11:29 AM
  5. First CHoice mower leaving uncut streaks
    By nhman in forum Attachments
    Last Post: 05-21-2004, 01:43 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
