FogBurn
If you are running the engine at pto speeds the shuttle is going to be very abrupt and really rough without the clutch, the engine needs to be running pretty slow to smoothly change direction. The HST pedal on the 60 series is light and easy to work i am sure it could run it with a stick if need be. Unless i am completely reading the parts diagram wrong it looks like the hst pedal just uses a electronic sensor so you may be able to relocate it anywhere you want in the cab as long as you can run wires. There is a plunger the goes through the floor but seems to only connect to the auto throttle advance cam, maybe it would work without this?
. I am only guessing though from quickly looking at the parts, worth taking a look at.
