Results 1 to 3 of 3
  1. #1
    New Member
    Join Date
    Aug 2014
    Posts
    1
    Cynthiana, KY
    JD 6410, JD 2020, JD X475, JD x485, JD 345
    Default 6410 Park / Neutral Switch
    I have a 6410 that quit going forward and reverse. I changed the power reverse unit and have a new park / neutral switch to install, not sure how to wire it up since new switch has different color wires. Checked all solenoids on the tranny already, checked good. Can never get voltage on either the forward or reverse solenoid. Will have voltage on the enable solenoid until i move the shuttle in either direction then the voltage drops out. Thinking that my wiring of the switch is causing this, but have tried different wiring scenarios. Checked fluid pressure (150 psi) and pressure switch. When shuttle lever is moved to either position it just beeps. Any suggestions please.
  2. #2
    Elite Member Zebrafive's Avatar
    Join Date
    Aug 2010
    Posts
    3,841
    South West MI
    John Deere 2030, John Deere 6415
    Default Re: 6410 Park / Neutral Switch
    The park neutral switch is to allow the tractor to start. There is another thread in JD AG tractors about a 6410 with the same problem. Tuned out to be a bad relay.
    John Deere 2030 JD 245SL Loader
    John Deere 6415 mfwd JD 640SL Loader
  3. #3
    New Member
    Join Date
    Jan 2015
    Posts
    1
    grapeland,tx
    john deere 6410
    im having same problem. what did you have too do to fix it
Similar Threads
  1. Should a JD 50 Series (5075E) start in Neutral when not in Park?
    By CobyRupert in forum John Deere Ag Tractors
    Last Post: 06-04-2013, 10:50 PM
  2. Jumper neutral switch
    By Roadyman7 in forum John Deere Owning/Operating
    Last Post: 02-14-2011, 07:35 PM
  3. Neutral Switch
    By ronz in forum John Deere Owning/Operating
    Last Post: 05-04-2009, 12:17 AM
  4. Neutral switch problems
    By Laneman950 in forum John Deere Owning/Operating
    Last Post: 08-18-2008, 10:16 PM
  5. Neutral Switch
    By Clemson in forum Massey Ferguson Owning/Operating
    Last Post: 05-29-2002, 07:02 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
