Page 1 of 2 12 LastLast
Results 1 to 10 of 19
  1. #1
    New Member n8210's Avatar
    Join Date
    Aug 2014
    Posts
    2
    Salley, South Carolina
    Massey Ferguson 165
    Default Cleaning Dust and Oil form the exterior of a deisel engine
    I'm working on a Massey Ferguson 165 with a Deisel engine. There's a lot of dust and grime on the surface of the engine. A rather sizable portion near the top looks to be wet with what I'm assuming is oil. (Doesn't smell like deisel) I'm thinking a leaking head gasket, but I don't think this tractor has been cranked in about a year. (Unless my brother has and didn't tell me.)
    What is the best / quickest way to clean this? (I hope this doesn't sound like too dumb of a question, but..) If I disconnect the battery, could I hit it with a pressure washer and then immediately run a blower to dry it, with out doing any damage?
    Thanks in advance for any help. I've attached some pics below.
    Here's what it looks like near the top of the block. I'm not sure if you can realy see the glint of wettness I was talking about in this pic.
    Cleaning Dust and Oil form the exterior of a deisel engine-0826141530a-jpg
    Here's a closer look.
    Cleaning Dust and Oil form the exterior of a deisel engine-0826141531-jpg
    There's also some dried on dust and grime.
    Cleaning Dust and Oil form the exterior of a deisel engine-0826141531a-jpg
    It wouldn't be complete without showing you the power steering cylinder where a bird built its nest.
    (I've removed the nest. Don't worry it was already empty.)
    Cleaning Dust and Oil form the exterior of a deisel engine-0826141532-jpg
  2. #2
    Gold Member
    Join Date
    Nov 2013
    Posts
    318
    SC
    Kubota L2050DT
    Default Re: Cleaning Dust and Oil form the exterior of a deisel engine
    I just bought some O'Reilly engine cleaner and sprayed it generously all over my old Yanmar a couple of days ago. Followed directions on the can.....spray, wait 10 minutes or so and wash off with garden hose. No pressure washer, no soap; just plain water. I did use a hose nozzle to focus the stream but not a heavy stream. Worked like a champ.
  3. #3
    Super Member jeff9366's Avatar
    Join Date
    Jan 2011
    Posts
    6,923
    Fanning Springs, Gilchirst County, North-Central Florida
    Kubota Tractor Loader L3560 HST 37-hp / 5,400 pounds operating weight
    "Simple Green" works well for me. Spray on, wipe off. Good oil and soot solvent.
    I would not pressure wash an engine.
  4. #4
    Super Member George2615's Avatar
    Join Date
    Feb 2005
    Posts
    8,119
    Central Square, NY
    LS XR3037HC
    Quote Originally Posted by n8210 View Post
    Since you have a pressure washer get some engine degreaser at an auto parts store and spray everything. Let it soak to do its job then wash off with your pressure washer.
  5. #5
    Join Date
    Dec 2012
    Posts
    1,199
    Ottawa, Ont
    Ariens
    diesel engine ? ... just pressure wash away and be done with it ( wear glasses and an apron or rain suit)
  6. #6
    Super Member
    Join Date
    Feb 2002
    Posts
    5,306
    western,pa.
    Kioti DK 35
    Pressure washer.
    It will be fine.
    I pressure wash my tractors engine a couple times a year.
    Vince,
    Kioti DK 35
    Hustler Super Z
  7. #7
    Silver Member blackdog2086's Avatar
    Join Date
    Aug 2013
    Posts
    249
    SE Michigan
    JD 5115M, JD 4720, Kubota ZD326
    I second the Simple Green. Spray it on, full strength, on a cool engine and let it sit for 15-20 minutes. Spray off with a pressure washer (wide spray pattern, not too close) and you're good to go.
  8. #8
    Super Star Member
    Join Date
    Apr 2004
    Posts
    13,569
    SF Bay Area-Ca Olympia WA Salzburg Austria
    Cat D3, Deere 110 TLB, Kubota BX23 and L3800 Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
    Always used Gunk engine brite and medium pressure washer...
    With cars it was my job as lot boy to take the trades and steam clean the motors at the wash stalls... always used Gunk...
  9. #9
    Join Date
    Dec 2012
    Posts
    1,199
    Ottawa, Ont
    Ariens
    changing motors or trans up here in the 70's .... it was take the car down to the power wash shop ... clean the out side of the car , then lift the hood and power wash the engine / trans and undercarriage ...
    real easy to do work when all the old nuts , bolts and parts were clean and free of gunk ... and the mess was hosed down the drain ...
  10. #10
    Epic Contributor Egon's Avatar
    Join Date
    Aug 2001
    Posts
    20,800
    Nova Scotia, Canada
    Just use ordinary dish soap and pressure washer.
    The car wash works well too.
    Egon
    50 years behind the times
    Livin in a
    Worn out skin bag filled with rattlin bones
Similar Threads
  1. Deisel engine for TC 33D tracktor
    By ktmrace in forum New Holland Owning/Operating
    Last Post: 04-08-2013, 10:16 AM
  2. deisel pump for isuzu 2ab1 engine
    By bitumen in forum Parts/Repairs
    Last Post: 07-08-2011, 05:46 AM
  3. 3 cyl deisel engine-Perkins
    By Nat in forum Build-It Yourself
    Last Post: 05-26-2007, 02:21 PM
  4. Oil & Fuel Cleaning PT 1850 Engine Oil Radiator
    By SpringHollow in forum Power Trac
    Last Post: 05-18-2007, 09:47 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
