Snow FRONT SNOWPLOW?
   / FRONT SNOWPLOW? #1
pkav32
Massachusetts
john deere 2520
Has anyone out there mounted a Boss snowplow to a loader. I have a Boss Sportplow 7 1/2 ft. I lost the truck in an accident so now the plow just sits there. Bought a Frontier SB1164 because I use the loader all winter. Was wondering if anyone made or bought a quick attach for the plow. It obviously has the mount for the truck but I think I could make it work.
   / FRONT SNOWPLOW?
Sorry I have a JD 2520 with a H130 loader.
   / FRONT SNOWPLOW? #3
I made a mount for a myers plow once, it worked well. Let the chain make a float and was very happy with it.
   / FRONT SNOWPLOW? #5
Just one question though? Could it possibly be worth more to sell as is as a package and just pick up a Tractor Supply 3 pt rig or Craigs list special to butcher. If it's nice it seems a waste to butcher a serviceable truck blade in some circumstances.
Now if you do decide to weld one of these up do post pictures. I have an old one that I want a SSQD mount on. I sure would rather copy someone elses rig on that than reinvent the wheel. I hate grinding welds.:rolleyes:
   / FRONT SNOWPLOW? #6
A 7.5' plow would be too much for a 2520.
   / FRONT SNOWPLOW? #8
   / FRONT SNOWPLOW? #9
There are several here that have mounted snow blades to their loader.
I put a skid steer quick attach plate on an old 9' Western truck plow that I have been using for several years.
   / FRONT SNOWPLOW? #10
I still have the Boss lift cylinder plumbed into the original system, but you don't need to use that when the plow is attached to the loader. If you set and leave the lift cylinder in "float" mode with the electronic controls, the plow will hang off the cylinder like a chain. You only have to set the cylinder in float once, then you can unplug the controller and put it way. Another option is to remove that lift cylinder completely and replace it with an actual chain.
Eventually I plan to fab up a frame/sub frame mount for the plow and operate both the side-to-side and lift cylinders with the loader controller. With the loader detached, of course. I'm mostly just interested in doing this just because I have extra Boss bush beam parts from my old plow truck and think it would be an interesting project to try.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A51039)
2017 Yale GLC050VX...
2015 CATERPILLAR 259D SKID STEER (A51242)
2015 CATERPILLAR...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A51219)
2019 INTERNATIONAL...
Ford Super Duty 8ft. Truck Bed (A49346)
Ford Super Duty...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
30ft Pole S/A Towable Trailer (A49346)
30ft Pole S/A...
