Page 1 of 3 123 LastLast
Results 1 to 10 of 30
  1. #1
    Member adimice's Avatar
    Join Date
    Jan 2014
    Posts
    31
    West central Virginia, Mid Coast Maine
    Kubota L4330 L 3830
    Default Overfilled Hdy/Trans
    Like the title says, I overfilled the reservoir on my L4330 HST. If I pull one of the 4 drain plugs, I'll have a gusher! I'm probably 2 qrts over. Anyone have a suggestion? Thanks
  2. #2
    New Member
    Join Date
    Nov 2013
    Posts
    24
    Central VA
    Kubota L3200
    Default Re: Overfilled Hdy/Trans
    I did the same thing with mine I guess. I couldn't see the fluid on the sight glass, so I added fluid, and added fluid, and added fluid. Still haven't seen it on the sight glass, but I quit adding fluid...
  3. #3
    Veteran Member jimmysisson's Avatar
    Join Date
    Jul 2005
    Posts
    1,648
    W.Mass
    1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
    Default
    Siphon?
    Jim
    "Anything worth doing is worth doing slowly" Mae West
  4. #4
    Join Date
    Nov 2014
    Posts
    181
    Texas
    Mahindra
    Four drain plugs seems a bit much. Are you doing this while the tractor is on or something? shouldn't have pressure on it when you pull a drain
  5. #5
    Veteran Member Pete Judd's Avatar
    Join Date
    Aug 2010
    Posts
    1,007
    The Thin Gravy Ranch in The wet PNW
    Yanmar 186d, JD 314
    Pull the plug with a clean bucket to catch the overage, and save for reuse.
    Yanmar 186D 1981
    5 foot Unknown brush hog.
    5 foot HF Finish mower.
    5 foot J-Bar back blade.
    HF Quick Hitch.
    Home made land leveler.
    Countyline Middle Buster.
  6. #6
    Join Date
    Jan 2014
    Posts
    31
    Kubota L4330 L 3830
    There's almost 12 Gallons, that's gallons, in the res. You open any of those drains , and it's a tsunami. There's a smaller plug on each of the rear wheel hubs, but even opening them and the oil squirts all the way over to the other wheel.
  7. #7
    Join Date
    Dec 2010
    Posts
    86
    JD 3520
    You can get a cheap hand pump from any auto parts store & pump out the excess back into the container.
    You may need to be creative to snake it to the fluid level, but odds are it'll slide right in. Make sure the hoses are secured tight & pump is primed before starting.
    It seems like modern machines hold more fluid(s) when "drained" than they used to... follow the manual at your own risk--will likely overfill if stated capacities are replaced!
    I've been stopping at ~80% listed capacity & gone real slow afterwards about the last ten years, but I never quite get to the actual capacity thats stated in any manual before hitting the mark.
  8. #8
    Join Date
    Dec 2012
    Posts
    1,023
    Ottawa, Ont
    Ariens
    5 foot piece of clear tubing .. siphon anyone ?
  9. #9
    Super Star Member dave1949's Avatar
    Join Date
    Apr 2009
    Posts
    10,984
    Industry, Maine
    New Holland TC40
    Quote Originally Posted by brown40 View Post
    Me neither, no matter how long I let it drip.
    I think the OP should just man up. Take off his shirt, lay some papers and rags down around the drain pan, open the drain plug until enough gushes out then put the plug back in.
    "Those were the days my friend, we thought they'd never end ..."
    When there is a huge solar energy spill, it is called a "nice day"!
  10. #10
    Join Date
    Dec 2009
    Posts
    1,362
    Kansas...USA
    Kubota B2620 (2012)
    Quote Originally Posted by dave1949 View Post
    Yeah, that'll work. Just don't use the kitchen hand towels or you'll really have a problem.
    Kubota B2620 HST
Similar Threads
  1. Hdy oil
    By robert holter in forum Yanmar
    Last Post: 05-14-2014, 01:14 PM
  2. J D 2010 HDY. PUMP
    By 309 farm in forum Parts/Repairs
    Last Post: 03-09-2013, 05:24 PM
  3. ID Hdy Pump
    By Kirk-NJ in forum Hydraulics
    Last Post: 11-07-2009, 07:37 AM
  4. 3 pt Hitch hdy. problem
    By snr8715 in forum Mahindra Owning/Operating
    Last Post: 01-16-2009, 09:38 AM
  5. Tranny/hdy fluid
    By MoKioti in forum Kioti Owning/Operating
    Last Post: 01-29-2007, 10:44 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2014 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
