Ballast Anyone Use Bar Bells as Rear Wheel Weights????????
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #1
Bulverde
Bulverde, Texas
JD 4500
I hear that a company makes a rear wheel mounted mounting kit that allows you to use regular weights from a standard gym type weight lifting set. the idea seems simple but I don't know if it will work as well as standard (but expensive) wheel weights.
Has anyone used this system? Any pros and cons? Do they clatter, break, etc?
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #2
Hi...
Waiting for delivery of that hardware kit right now... so I have no use history....
Bought (6) 50# barbell plates... ~50 cents a pound new...
This setup is about 1/2 the cost of tractor wheel weights...
Will be easier to mount/dismount the weights... just 1 nut to remove...
Easier to change amount of weight...
Dave...
What company sells these?
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #4
Please let the TBN members know where you got the kit as I would like to try them myself. Thanks.
I found this link in an earlier post.
EZweights
IS this where you bought them?
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #6
Yep... EZWeights...
Mine are a custom size... and had the rods made longer too...
$82 including shipping...
Dave...
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #7
Yes - EZweights. They are great!
The brackets are about $36/pair and hold 1" plate weight. I bought my used weight for about 20 cents a pound from a Play it Again Sports store. 400lb = about $80 + brackets = about $85, incl tax and shipping. I have had them a year and have had absolutely zero problems with them.
They are simple to get off and on, since you only handle up to 50lbs at a time. During mowing season, they are off (along with the loader) when moving and on when using the loader. Takes less than 3 minutes. No rattles. Very stable. Highly recommended!
Picture attached.
Mark
Seems like a better alternative. Is 400 lbs on the back enough for a JD4500?
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #9
Here's a link about my experiences with a set of brackets 5030 made for me. No clattering, no breaking just cheaper than the OEM set up.
   / Anyone Use Bar Bells as Rear Wheel Weights???????? #10
Mine are almost the same way as Ez's. I made mine about 4 years ago, long before Ez came to the bar. /forums/images/graemlins/grin.gif There are not negatives compared to factory weights. They are less costly and easier to put on and remove. I would recommend this type on weights for anyone that needs wheel weights.
