Dave5264
Gold Member
- Joined
- May 25, 2009
- Messages
- 374
- Location
- Near North Ontario Canada
- Tractor
- 08 Montana C5264, 2011 McCormick CX100 XS
Hi All, Im goingto try plowing for the first time this weekend. I got a used 3 furrow plow in the summer (Swiss or swedish I think, cant recall the name, starts with an "o"), supposed to be an excellent plow.
Im using a 2011 McCormic CX100 Xtra Speed (build by Case) Tractor.
Ground is generally very heavy pure blue clay below the top soil, so ground is typically very hard in summer and awfully soft in spring after the thaw. Ive read its best to plow such ground in the fall.
We have had enough rain in the past few weeks to soften the ground up, so as long as its not wet this weekend I will give it a go.
Im going to do a 5 acre field to begin with, Ill start in the center and work out.
the plow has a depth wheel, So for setup i guess its a case of settign the right depth, leveling via the top link and knowing how far the drop the 3pt arms ?
I believe I have to make sure the side to side stablizers are not rigid but has slack to allow the plow to move a bit as well.
sounds simple enough but Im sure its easy to make a mess of it , any other tips ?
Im trying not to get too worked up over it, after all its just dirt so it can all be made pretty again
