roygul
Member
- Joined
- Apr 30, 2009
- Messages
- 40
- Location
- Brisbane North
- Tractor
- Jd 2305,Antonio Carraro trx 9400, JD 10 TLB
Have a small project of putting a single layer of sandstone blocks before a steep drop, about 25 stones. It will use either of these blocks. I 'm going to dig a shallow trench 8 inches deep fill with sand for a couple to make leveling easier.
16x16x40 inches 815 lb (400x400x1000mm 370 kg)
20x20x40 1278 lb (500x500x1000mm 580 kg)
I have a jd tlb 110 with 4 in bucket and thumb on the backhoe.
I'm a little concerned if I use the 4 in one bucket to grab stone with I will damage the edges.
I have some $$ in the kitty for tools maybe a grapple bucket. I think the backhoe will lift the smaller block but will struggle with the larger ones.
My better half of course likes the bigger blocks, and I am sure if this project is a success more blocks will turn up for other projects around the property
Thanks
Roy
Thanks
Roy
