The tractor has to be in the ditch with a box blade. You are saying that the left side won't go deep enough? You should be able to get roughly a 10* cut. The second time through you would then be at about 20*. I would not want to be going through a 3rd time.
I would not want to even clean out a 20* cut with a std wheeled machine. :no:
QUOTE]
Brian, as I was reading this thread and saw your querying the need to get a deeper cut, I was thinking, well what's wrong with that?
I had to laugh out loud when I saw your explanation above, because I had that exact light bulb moment only yesterday.:ashamed:
I was going to clean out an old ditch drain with my rear blade and thought "I'm going to have to get a lot of tilt on the blade to match that angle in the ditch". I don't have the luxury of hydraulic tilt so spent 15 mins moving the pins on the blade (and swearing and sweating) to lift one side and lower the other the maximum I could(3 mounting holes on each side).
I drove up to the start of the ditch, dropped the blade and took off, pleased that I had this job sorted. Then - holy **** why I am I gouging out so much dirt?
Of course, I had not realised that the tractor would already be on the angle - another rookie mistake, no harm done, but just goes to show its easy to outthink yourself when you are not too smart to start with! :laughing:
