Ballast Question About Tractor Weights
   / Question About Tractor Weights #1
cooljoe00
Member
Nichols, sc
Kioti NX6010HST Cab
Okay I been reading through the forums I read a lot about when to use weights and where to put them; but nothing about how much. I was looking to see if there was a general rule like if I am only Font loader lifting thing under 500lbs used 10%(50lbs) rear ballast. Or if I am mowing/grading use X(lbs) front weights. Also I was wondering is it bad to only fill(rim-guard) the rear tires if the tractor is 4wd(AWD) seems like it would be? One other thing if I did fill all tires how bad on fuel would it be if I was just mowing for extended periods of time? Oh and does filling all the tires change how much front/rear ballast is need for these thing?
   / Question About Tractor Weights #2
Okay I been reading through the forums I read a lot about when to use weights and where to put them; but nothing about how much. I was looking to see if there was a general rule like if I am only Font loader lifting thing under 500lbs used 10%(50lbs) rear ballast. Or if I am mowing/grading use X(lbs) front weights. Also I was wondering is it bad to only fill(rim-guard) the rear tires if the tractor is 4wd(AWD) seems like it would be? One other thing if I did fill all tires how bad on fuel would it be if I was just mowing for extended periods of time? Oh and does filling all the tires change how much front/rear ballast is need for these thing?[/QUOTE
Check your owners manual for rear tire ,and 3 point ballast to us use your loader safely.
Nobody is going to give you the specs you want,.to .much to liability;)
Go by the book...be safe, keep everyone out of trouble.:thumbsup:
   / Question About Tractor Weights #3
Most owners manuals will recommend not filling front tires. The FEL will transfer weight from the solid rear axle to the tippy front axle, even an empty FEL. A load will transfer more. The whole point of rear ballast is to transfer that weight back to the rear axle. That will only happen if the weight is behind the rear axle. Loaded tires help with traction and stability, but do not cause that weight transfer backwards.
   / Question About Tractor Weights #4
Will you be operating on slopes fairly often?
I mow with a Land Pride medium duty, 60" RCF2060 Rotary Cutter. Occasionally I drop off the bucket from the FEL when mowing. I never feel the need for additional front end weight when mowing.
My ground is flat. My small tractor is fairly heavy. My small tractor has 4-WD. My tires are filled only with air. For FEL work I use three point ballast only. This works for ME.
If you will be mowing COMMERCIALLY, punctured tires are part of the game. You do not want loaded rear tires and a puncture together.
Soggy Water Oak in the photos was around 1,600 pounds. Rollover Box Blade is 630 pounds but CANTILEVERED FAR BACK making greater EFFECTIVE counterbalance. (Maybe 1,000 pounds EFFECTIVE counterbalance?)
Buy enough tractor.
   / Question About Tractor Weights #5
My ground is flat. My small tractor is fairly heavy. I use three point ballast only. My tires are filled only with air. This works for ME.
I mow with a Land Pride medium duty RCF2060 Rotary Cutter. Sometimes I drop the bucket off the FEL when mowing. I never feel the need for additional front end weight when mowing.
And that would work for 90% of all other scenarios too.
   / Question About Tractor Weights #6
Look at your owners manual. Mine gives many good suggestions. First - they recommend not filling the front tires. Second - there is a maximum amount that the 3-point can lift - don't go beyond that. Third - adding ballast(liquid) to the rear tires, only, will not affect the 4WD system negatively. Fourth - the owners manual may recommend, as a starting point, the amount of weight to put on the 3-point.
I'm sure any weight added to the rear tires will decrease your fuel economy marginally. However, the increase in safety - if you need the weight - will more than offset any added fuel used.
   / Question About Tractor Weights #7
Keep in mind the more ballast you have on the rear the more weight your front axle will take.
Say if you can't handle a full bucket so you add ballast to the rear. Now you are putting the extra weight of the load plus the equal weight from the ballast on your front axle. This can add up quick.
I deal with these scenarios on a daily basis and I bet you can guess what it is by my screen name!
   / Question About Tractor Weights #8
Most owners manuals will recommend not filling front tires. ...... That will only happen if the weight is behind the rear axle. Loaded tires help with traction and stability, but do not cause that weight transfer backwards.
Not sure where you came up with this, but it ain't so....I believe any additional weight behind the lateral center of gravity (ie. fulcrum point) will aid in additional ballast....including your butt sitting on top of the rear axel. Fact: weighted rear tires WILL help.
   / Question About Tractor Weights #9
Weighted rear tires will keep the tires on the ground when lifting heavy loads BUT without some load on the 3 PH, the loaded rear tires would enable more stress to be placed on the front axle when lifting a heavy load.
You said that weight needs to be behind the fulcrum point which is true. Loaded tires are on the fulcrum point which is the rear axle. Weight has to be behind the rear axle for it to start reducing the load on the front wheels. The further the load is extended behind the tractor the more effect is has. A 1000# ballast box is not as effective as a 1000# bush hog which extends 6 feet or more behind the tractor. A ballast box is great for working tight places though and it does reduce the load on the front axle by the amount of weight that the ballast box carries.
   / Question About Tractor Weights #10
You conveniently omitted my previous statement that the primary goal was transfer weight backwards. And as Gary points out below, loaded tires will not accomplish that.
