steve kay
does anyone have experience or knowledge of replacing the bottom driver side door glass on a ToolCat 5600?
Well you didn't say what Series or year it is.does anyone have experience or knowledge of replacing the bottom driver side door glass on a ToolCat 5600?
If it's glued in you can buy a tube from most automotive parts stores. It comes in fast set or overnight. You will want the fast set. If you can remove the door and lay it flat it will be real easy, otherwise you will have to use duct tape to hold the glass in place and something like a couple thin pieces of rubber for the glass to set on while the urethane dries. You just use a utility knife to remove as much of the old glue and then wipe the frame down with something that will take any dirt or grime off. The glue comes in a tube that you apply with a caulking gun. You need to put down a bead think enough so the window will sit about the same depth as the old one was at but not too much so it squishes out. The glue is real messy so try not to get it on anything other than where you want it. I do believe rubbing alcohol will remove it off of painted parts before it dries. If you get it on your hands and it dries it could take weeks before it wears off. The glue is very strong and sticks well to most surfaces.
