Results 1 to 9 of 9
  1. #1
    Join Date
    Apr 2013
    Posts
    554
    DFW, TX
    IH 584, NH TC33DA, NH TN95A
    Default How did I do that?
    I was shredding between trees. Done it many times. Came back around and it did not look like it has cut right. I looked back at the shredder and it was sitting funny, so I checked a little better and a hitch pin had disappeared. I got the shredder lined back up and put a new hitch pin on. It was late so I parked the tractor.
    The next day I decided to take the shredder off and when I did, the shredder looked funny again. "So that's why it looks funny" Now, How did I do that?
    How did I do that?-img_2927-jpgHow did I do that?-img_2926-jpgHow did I do that?-img_2929-jpg
    Veteran US Army Infantry
    Life member Vietnam Veterans of America
  2. #2
    Elite Member Wagtail's Avatar
    Join Date
    Jan 2013
    Posts
    4,471
    St Helens, Tasmania, Australia
    JD 4105 / JD D110
    Default Re: How did I do that?
    Nice one! Just goes to show not only how powerful tractors are but that they're truly designed to 'pull'... so much so that you barely notice when you've 'pulled' something you shouldn't have, eh?
  3. #3
    Join Date
    Apr 2013
    Posts
    554
    DFW, TX
    You are so right! I went from 13 in wide tires to 18.4 wide. Now my 58 hp tractor will out pull my 400 hp truck. (I am sure the tires have a lot to do with it.)
  4. #4
    Elite Member gwdixon's Avatar
    Join Date
    Jul 2009
    Posts
    2,999
    Northern CA
    After the skidder gets straightened (or replaced) and welded back on, you may consider hardfacing the ground contact area. The skidder gets thin from wear and is displaced much easier.
    Hardfacing in a crosshatch (#) pattern has reduced the wear in several of my implements. Tillers especially have the same problem and the wear bar (landslide) on a plow are the most notable.
    How did I do that?-plowpainted_02-jpg
    2009 Kubota M7040, R1s, LA1153 FEL, fork lift, 3 rear remotes, T&T
    2002 Kubota L48 TLB, 12", 18", 24" HD buckets
    2001 Kubota BX2200, Turf, LA211 FEL
    7.5' Howse 3PT disc, 88" Gearmore 4G4 box scraper, 4' box scraper, Gearmore GB85 blade, LandPride RCR2596 cutter, 6', 4' flail mowers, 6', 4' rototiller, 4' Bush Hog cutter, HD subsoiler, Bearcat 70554 chipper, Bush Hog PHD w/ 12", 6" augers, Ford 101 3-bottom plow, 8' land leveler, 6' rake, lots of misc.
  5. #5
    Platinum Member MF283's Avatar
    Join Date
    May 2009
    Posts
    697
    Lebanon, TN
    JD 5303 JD 920M JD825I XUV Gator
    I don't know how you did it, darn fine job of doing it though
    Haven't seen to many tractors i didn't like, just partial to Deeres.
  6. #6
    Super Member bindian's Avatar
    Join Date
    Feb 2007
    Posts
    6,515
    Willis, Texas
    Mahindra 6520 4WD
    Straighten it out and tack it back. From the shininess on both sides, I would say you had it set too low and was constantly dragging when you started. Raise it up with a little air between it and the ground.
    ccchugs, Brandi
  7. #7
    Join Date
    Oct 2003
    Posts
    1,271
    Kentucky, West of the Lakes, South of Possum Trot. North of Coldwater, Near Golo
    Kioti CK20S, Ford 4600
    Default
    Doesn't look like anything you can't fix with a log chain and a large tree. Then flip it over and beat the he11 out of it with a sledge hammer. Finally tack it to the frame with a welder. Good as new.
  8. #8
    Join Date
    Apr 2013
    Posts
    554
    DFW, TX
    Quote Originally Posted by RSKY View Post
    A new one will cost $23.
  9. #9
    Join Date
    Feb 2007
    Posts
    6,515
    Willis, Texas
    Mahindra 6520 4WD
    Quote Originally Posted by ch1ch2 View Post
    Where's the fun in that? When I was rebuilding helicopters, I wanted to turn wrenches on them too. My airframe rebuild boss said I didn't wanna be a parts changer.............like the mechanics! Never turned a wrench on one, but I could rebuild anything on a Bell 204, 205, 206 and 212s and Sikorsky S-76.
    hugs, Brandi
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
