Musdalen
Gold Member
S219 has a great thread on http://www.tractorbynet.com/forums/owning-operating/374249-my-new-customized-ballast-box.html. His timing is impeccable for me as I have a new tractor on order (JD 3039 with FEL and grapple) and will be needing to make one as well. And I have somewhat similar ideas, but nothing like his fabrication skills - and I'm a cheap bastard.
What I do have is a King Cutter, 3-pt carry all that is rated for 1000 lbs. It looks like this
and it is 36" deep (front to back), and 28" left to right. I too would like to have a receiver hitch on it so I could use it to drag logs and move a horse trailer from time to time.
My thoughts are to cut the two forks shorter by at least a foot. and then having a piece of angle welded between them and probably braced to the back as well. Then deck with treated 2x6's and build a temporary wooden box to fill with lead and concrete. I don't have any metal fabrication skills so I would like to keep the welding work to a minimum as I will have to pay to have it done. but what would you guys suggest for bracing, if any, and any other modifications (maybe some tiedowns on top for my chainsaw and tow chain?).
