whitefacenh
- Joined
- Jul 21, 2006
- Messages
- 8
I have an Kubota L3710HSTC with a set of dual remotes installed. The problem is that I need to run a Single Acting cylinder on a Batwing Mower with only one hydraulic line running to the cylinder. When I try to plug this into either port of my remotes nothing happens as their is no flow through the unused remote. The mower wont go up or down. Makes since to me. However, when I called the Kubota dealer they indicated Kubota does not have a "single port" remote as an option. They also said I should be able to run the mower cylinder using jus tone side of the remote. They transferred me to the service department who also told me the same thing What am I missing? Is it possible to make a one line single acting cyliner work on a dual port?
