Weedaway
Member
I have a 1973 David Brown 885. It has no power steering and I've been advised against fitting a FEL as it will risk damaging the steering box and parts are NLA. Therefore I plan to be working with rear attachments only. These tractors are renowned for being front-light. If I want to ballast the front is it better to use chassis weights or wheel weights? I'm thinking if I weight the chassis then whenever I don't have much rear load I'm stressing the steering. Would using wheel weights instead reduce this stress? I can't quite get my head around it. :confused2:
