blb078
I just finished building my house at the end of spring/beginning of summer. Just before we moved in I had the back yard done with hydro seeding(that green spray stuff), it was done commercially by a company that does it around my area, not a HD /Lowes DIY job. About a week or so after the seeding on the back was done we had about 8 straight days of non stop hard rain, those of you in the midwest know what I'm referring to and pretty much washed and rutted everything out. And what you see in the first pic is what is left over from the hydro seeding after the rain did it's thing and me cleaning up what I could with my tractor. I did some fixing up with the bucket and ratchet rake. Pretty much nothing came in and the spots that did it where not thick at all due to all the rain. When the rain finally stopped after a few weeks of off/on every couple days it was pretty much summer here and I've never had good luck getting grass to grow in our summers due to the heat, right now it's 101* out and it's been near this hot for a couple weeks and probably will be for a couple more so Sept is my last shot before winter.
The ground is clay, grass will grow in it but I may put down some top soil in certain areas, you can see some of the loads of soil in the pics and I'll probably bring in 3 or so more loads. I've gotten most of the sticks, rocks, ect out just using the ratchet rake and even able to clean up some of the weed areas with it, just takes a few passes which is no biggie. One of the issues is that I don't really have any implements. I have my bucket and a ratchet rake and that's pretty much what I've been using to keep the ruts out from rain run off and limit the weeds growing. Although some areas the weeds have taken over as you can see around the driveway and walkway. I thought about renting a tiller or plow but no places around me seem to rent them. So then I looked on craigslist and not many tillers on there and the few I've seen are either 4' or 5'. I'd need a 6'. So would buying a tiller and breaking up this ground be worth it? I guess I can probably use the tiller in the future for a small garden. The rural king king kutter brand is about $2k which I guess I can stomach because it was $2600 for the hydro seeding and that didn't turn out that well.
So my thinking is buy a tiller(if I have to), and either a rotary cutter and finish mower or a flail mower(leaning towards a flail since it can do the job of both and I don't have very thick stuff that needs to be cut). Use the flail to get some of the taller weeds down(you can't see it all in the pics) then the tiller to break it all up and get ready for seeing and then my bucket to smooth it out. Anyone have any other suggestions that might be cost efficient and get the job done? I'm trying to avoid buying the tiller if I have to but I don't think it's gonna work out without something like that. So any and all suggestions are welcomed because I've have about 6 weeks before I need to get this started. And like I mentioned renting isn't an option and craigslist for used items seems to be very limited. Thanks
back yard after cleaning up from rain
front yard
another front yard view
this is was the back yard looked like right after the hydro seeding, unfortunately the rain wasted this.
front yard
