Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. #11
    Elite Member
    Join Date
    Sep 2007
    Doniphan, Mo.
    Kubota L4240, B7800 & BX2660
    Default Re: Tired of banging my head on this thing!
    Sounds like the top link mount on the carry all is to high. Should be around 15 to 16" up from the bottom link pins. Show a picture of the carry all hooked up to the tractor.
  2. #12
    Join Date
    Jan 2010
    Piedmont, NC
    Kubota L4610 & BX2230, Farmall Super M, Super A
    Quote Originally Posted by kneedeep View Post
    Better off without it, false sense of protection and is dangerous.
    A bit of sarcasm, I hope?
  3. #13
    Platinum Member jodebg's Avatar
    Join Date
    Mar 2012
    New Hartford, CT
    Kubota B-2650
    Hi Leejohn
    I don't have the carry all mounted. I did measure the pin locations on the carry all = 17 1/2"
    When I began looking for a B2650, I noticed that most of the owner photos were with the rops pinned
    in the horizontal position-seemed odd.
    I asked a few owners and they told me that the top link hit the rops so they set it and left it up to avoid problems.
    I took comparrison measurments on the B7800 and found the rops sits 4" higher when folded down.
  4. #14
    Gold Member Slowpoke Slim's Avatar
    Join Date
    Jan 2017
    Bismarck, ND
    Husqvarna YTH24V48 riding mower, Branson 3725CH
    Ok, what am I missing?
    Why not just raise the ROPS all the way to it's vertical position? Like it's supposed to be? Then it won't hit the top link at all, right?
  5. #15
    Elite Member oldballs's Avatar
    Join Date
    Dec 2009
    Kubota B2620 , Case 448 , Kubota B2650
    I suppose the ROPS could save me from some major when used as designed. But I've gotten plenty of minor hurt from "banging my head on this thing!" too, Since it has to be lowered to get into my garage for service or for parking in my Shelter, I am raising it and lowering it all the time. Thus I hung some red 2 foot ribbons on the dang thing that give me some warning when it is at half mast. Especially hooking up implements or just walking around I have had some real "Bumps".
    The one bump that I really fear is when the ROPS is raised and needs to be lowered after the last pin is removed. If it came down and whacked me in the noggin' I'd probably be laving on the ground.
    So John,,,,,,,,,,,you ain't the only one.
    Kubota B2620 (2012) Case 448(1983) Kubota B2650 (2018)
  6. #16
    Veteran Member bdog's Avatar
    Join Date
    Mar 2004
    John Deere 4440
    Looks like it will do the job. There is always a risk but with flat ground unless you are really reckless you are more likely to get hit by lightning than roll your tractor.
    Call the safety police but I never wear the seatbelt unless I am doing something really risky and I would assume many other operators don't either and the rops doesn't do much good if you are not strapped in.
    1980 John Deere 4440
    2006 John Deere 550 J dozer
    2016 John Deere 333E compact track loader
    2018 John Deere 35G excavator
  7. #17
    Join Date
    Dec 2015
    New Holland Boomer 24
    Safety issues aside. I am confused. You can't lower ROPS. So you removed it. Then you built a wood replacement. Why not just raise the ROPS to it's intended position?
    Edit- I see bow. You need ROPS lowered to get in the garage.
Similar Threads
  1. Clanking and banging in 4wd
    By 1234567A in forum Kubota Owning/Operating
    Last Post: 04-15-2014, 10:44 PM
  2. MX10 blades banging between spindles, help please
    By gbugh in forum Parts/Repairs
    Last Post: 05-13-2012, 03:13 PM
  3. Banging noise on my new B2789 snow blower
    By check in forum Kubota Owning/Operating
    Last Post: 12-30-2010, 12:06 PM
  4. Banging deck
    By chucko in forum Kubota Owning/Operating
    Last Post: 02-22-2004, 09:27 PM
  5. bx2200 60mmm banging
    By oombala in forum Kubota Owning/Operating
    Last Post: 11-12-2002, 02:34 PM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
