Page 2 of 5 FirstFirst 12345 LastLast
Results 11 to 20 of 43
  1. #11
    Join Date
    Dec 2013
    Posts
    1,932
    Southern Alberta, Canada
    4410 and F-935 John Deere, MF 245
    Default Re: Can you use a metric socket on a sae bolt? socket set questions.
    Quote Originally Posted by lpigott View Post
    11/16 = 17mm
    An 11/16" will work on a 17mm. Not the other way around unless the 17 is pretty sloppy. I find even the 1/2"/13mm to be a stretch. The 13mm will fit on the 1/2" but 1/2" on a 13mm is a pain. Your always fighting it on and off unless it's worn a bit.
    !/4" = 6.350mm
    5/16 = 7.938mm This one interchanges pretty good. Think GM battery bolts
    3/8" = 9.525mm
    7/16" = 11.112mm
    1/2" = 12.7 mm
    5/8" = 15.875mm
    11/16" = 17.463mm
    3/4" = 19.05mm This one also interchanges pretty good.
    13/16" = 20.638mm
    7/8" = 22.225mm
    15/16" = 23.813mm
    1" = 25.4mm
  2. #12
    Veteran Member DieselBound's Avatar
    Join Date
    Aug 2016
    Posts
    1,563
    Arlington, WA
    Kubota B7800; Kioti NX5510HC
    Keep in mind that not all spec'd sockets are the same spec. I've sometimes used an SAE in place of a metric (even though the metric is supposed to be right) because the metric socket isn't in perfect agreement with the bolt/nut; and, vice versa. That is, I'll grab something and test fit. I don't care what it says on the outside, I care whether it fits properly. I suppose that $20 a piece SnapOn sockets are manufactured to excellent tolerances, but I ain't a professional mechanic and therefore cannot justify (cost wise) having a stockpile of them. I don't know what's faster, measuring and then finding the right size OR grabbing and trying... but, my observations have been that even if you think you have the right size it might not be a good fit (grab again!).
  3. #13
    Super Member Wagtail's Avatar
    Join Date
    Jan 2013
    Posts
    6,030
    St Helens, Tasmania, Australia
    JD 4105 / JD D110
    Sorry but I'm in the 'buy the proper socket' camp. My JD's are all metric and I bought the JD metric set of tools (heck, I was in the parts shop anyway so 'why not?') But I also bought a small set of SAE sockets too... just in case.
    I've used exactly one of those SAE sockets so far; but I had it!
    It's not going to be just your tractor(s) that you're going to be working on either. Implements all tend to loosen up due to usage and general vibration.
    Get'em on sale, an early Christmas pressie or for your birthday.
    [Treat yourself to a torque wrench while you're at it. ]
  4. #14
    Elite Member Redneck in training's Avatar
    Join Date
    Nov 2008
    Posts
    4,180
    South Central Iowa
    TYM 330 HST with FEL
    Not all sockets are created equal. Sockets with "lobes" generraly have better grip than straight hexagon. Snap On or Metrinch are examples. There other brands too.
  5. #15
    Super Member RickB's Avatar
    Join Date
    Sep 2000
    Posts
    9,359
    Lincoln County, NC need new avatar!
    Just a Scag
    Quote Originally Posted by pmsmechanic View Post
    !/4" = 6.350mm
    3/8" = 9.525mm
    7/16" = 11.112mm
    1/2" = 12.7 mm
    5/8" = 15.875mm
    11/16" = 17.463mm
    13/16" = 20.638mm
    7/8" = 22.225mm
    15/16" = 23.813mm
    1" = 25.4mm
    Nobody suggested the Imperial wrenches work on metric hardware. The OP has metric tools.
    Spring is the season of optimism.
  6. #16
    Join Date
    Dec 2015
    Posts
    929
    Indiana
    New Holland Boomer 24
    I can't remember what I paid for it, I am sure it was less than $100, but the first set of sockets I bought had both imperial and metric in the box. Also had deep sockets and not deep. They are even craftsman and at that time said made in the USA on the box and on each socket.
    Of course you could get 64 Pc 1/4 in., 3/8 in., 1/2 in. Drive SAE & Metric Socket Set if you are just going to use it occasionally.
  7. #17
    Super Star Member LD1's Avatar
    Join Date
    Apr 2008
    Posts
    17,767
    Central Ohio
    Kubota MX5100
    I agree you need both sets. But sometimes you just don't feel like spending half an afternoon looking for where you last placed a given size.
    5/16 = 8mm
    7/16 = 11mm
    9/16 = 14mm
    5/8 = 16mm
    3/4= 19mm
    7/8= 22mm
    15/16 = 24mm
    Those I will use interchangeably with no concerns.
    1/2 and 13mm or 11/16 and 17mm I will use in a pinch.
    Absolutely nothing close for 10mm, 12mm, 15mm, or 18mm
    ".........there is only one way to find out."
    "Ok, hold my beer and watch this.........."
    MX5100 DIY Remotes
    MX5100 Diverter install
    Front Snow Plow Install
    Ford 5500 Backhoe
    Kubota MX5100HST w/LA844
    2005 Dodge 3500 4x4 Diesel
    8N Rebuilt and restored
    Bushhog 306
    3 Homemade wood hauling trailers
    Dolmar 6400 84cc ported
    Sachs-Dolmar 120SI Ported
    (4) Sachs-Dolmar 116SI Ported
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
  8. #18
    Super Star Member Gary Fowler's Avatar
    Join Date
    Jun 2008
    Posts
    10,644
    Bismarck Arkansas
    2009 Kubota RTV 900, 2009 Kubota B26 TLB & 2010 model LS P7010
    Over the years I have bought sets of both sockets and wrenches in SAE and Metric. None of them are high dollar yet all have worked pretty well. I did break the jaw on one wrench (9/16" I believe) and welded the jaw back on with a 7018 rod and it is still holding. I did have to grind the jaws a bit for proper fit.
    I also bought a set of 1" drive sockets from Harbor Freight that have worked well. One is metric an one is SAE both go up to 2 or 2.5" I think. Each was around $60 (several years ago) and I have used them on my tractor and equipment even with an impact and no damage.
    Every home mechanic and or tractor owner needs a complete set of SAE and Metric sockets and wrenches and they don't have to be high dollar to work sufficiently for occasional use. I have a mixture of Craftsman, Stanley, Kobalt and a few with no name brand like the HF stuff and most have been very good.
    2010 LS P-7010C 20F/20R gear tractor & FEL, 2009 Kubota B 26 TLB, RTV 900 Kubota,17 foot Lund boat with 70HP motor, 2012-20 ft 12k GVW trailer, 2011- 52" Craftsman ZTR mower, 2013 Ferris Zero Turn, 3 weed whackers, pressure washer, leaf blowers, 7 foot bush hog, 8 foot landscape rake , 8 foot 3 PH disc, 2 row cultivator, 350 amp Miller AC/DC welding machine and all the tools needed to keep them all repaired and running.
  9. #19
    Gold Member
    Join Date
    Oct 2015
    Posts
    353
    Kalamazoo, MI
    Farmall C, JD 260 Lawn tractor
    To answer the OP's fundamental question...no. You're in West Virginia, go to the nearest Harbor Freight store and buy some SAE sockets and wrenches. Heck, print off a few 20% off coupons and pick up a set each day on the way home from work.
  10. #20
    Join Date
    Apr 2008
    Posts
    17,767
    Central Ohio
    Kubota MX5100
    I find that once you get to big sizes like a 3/4 drive set, you only need one set. Metric or SAE take your pick. Because at those sizes tolerances aren't as critical and either will work.
    I do have a set of jumbo metric wrenches from harbor freight. 35mm, 38mm, 41mm, 45mm and 50mm.
    They work just fine as:
    1-3/8, 1-1/2, 1-5/8, 1-3/4, and 2.
    I honestly think they are the same 5 wrenches they sell as the SAE set, just different etching for the sizes
    MX5100 DIY Remotes
    Ford 5500 Backhoe
    Bushhog 306
    Dolmar PS540
    Sachs-Dolmar 115i
    Sachs-Dolmar 117
    Sachs-Dolmar 112
Similar Threads
  1. Nice socket set
    By Paul Thornton in forum Kubota Owning/Operating
    Last Post: 03-27-2016, 10:05 PM
  2. Socket set help
    By woodlandfarms in forum Parts/Repairs
    Last Post: 12-01-2012, 03:35 AM
  3. metric socket sizes
    By ron45 in forum Kioti Owning/Operating
    Last Post: 05-24-2012, 09:58 PM
  4. HF 3/4" socket set
    By kossetx in forum Parts/Repairs
    Last Post: 10-09-2006, 09:14 AM
  5. Socket Set question
    By Typhoon in forum Owning/Operating
    Last Post: 11-06-2004, 10:18 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2017 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
