I don't seem to be able to close the latch on the top link of my tractor. The sleeve turns easily on the threaded rod but I think I should be able to close the latch down against the sleeve to lock it in place and I can't. I can move the latch from open to about half way closed but this is as far as it seems to want to go before binding up.
Also I think you are supposed to be able to change the linkage category of the top link end by unscrewing the implement end of the top link. When I try to do this, my implement end is bound up and doesn't turn.
I put some oil down between the implement end and the sleeve in an attempt to loosen everything up but it hasn't helped. Anybody have any ideas about what is wrong or what I can do to free up the latch so that it will close?
Thanks.
Thanks.
