Georgehitch18
Hi guys, I recently bought a 2018 B2650 and I have Been using the FEL. After about 3 hours of use I noticed loss of lifting power and some other strange behavior. I noticed a few lines had a very minimal leak so I went ahead and called the dealer. They came picked it up claimed they went over the whole tractor and dropped it off. I get the tractor home only to discover I had leaks in the exact same places and still no power when raising and lowering the loader. I discovered that if I tipped the bucket while raising or lowering I gained full raise/lower speed.
I thought to myself no way did this dealer have it for several days and not do a dang thing. So I went out tightened the fittings myself and started searching for answers. After digging around the site I found out the cause was my 3 pt hitch arms were trying to go up higher than they were able to causing the pump to lose power on the hitch instead of giving me power for the FEL. I suppose the dealer did not operate the FEL with the hitch all the way up. Not sure why they did not tighten the fittings as it was clear which ones were leaking but I took care of that. I lowered my level from 10 to 7 and wallah it ran perfectly.
Back to the pump. I could hear the pump straining itself trying to get the 3 point to the set level before I discovered what was wrong and noticed it was whining louder than normal. I also know I had it running for quite a while trying to get air out of the hydraulic lines before I realized air in the lines was not the problem. Does anyone know if this would do damage to my hydraulic pump? It seems to be running perfect now but I do not want to have issues down the road.
Should I have the dealer come pick up the tractor again and adjust the hitch or is this something I can tackle myself?
If it is not extremely complex where might I find out how to adjust the hitch to prevent it from happening again?
Thanks in advance for any info guys. I love the tractor so far I just want to make sure it works perfect and lasts me for decades!
