First check belt routing. With belt off, check the tensioning system (lever arm, spring, grease fitting). The lever arm often freezes up from lack of attention. Wrong belt of course could cause this. While you are at it, check for correct blade rotation direction. Consignment experience: wrong deck for this tractor. Watch the pto rotation versus the blade discharge position.
