Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. #1
    Join Date
    Apr 2000
    Posts
    135
    Far Eastern Central MA
    Kubota B2710
    Default Garage Damage Prevention
    I have seen several posts in the past regarding damage to the door frame of garages/sheds caused by attempting to fit a an unfolded folding ROPS through an opening that was too short...
    In the first couple of months that I owned my tractor I had this problem twice and finally decided to hang a bright red piece of cloth from one of the hinge pins of the garage door so that it would hang down when the door was open and I would see it. It was supposed to remind me to check that the ROPS was folded before driving into the garage.
    This seems to have worked OK until earlier this spring when I rammed the garage door frame twice on two consecutive tractor outings. Apparently my absentmindedness had finally overcome my friendly reminder flag. [img]/forums/images/graemlins/blush.gif[/img]
    So, I had to come up with a better solution... My new sign hangs from the ROPS bolts when folded and reminds me to put hte ROPS up when I drive out of the garage. It then hangs from a cleat on the inside of the garage door frame to keep me from driving into the garage with the ROPS up. So far it has worked well and there has been no (aditional) damage to the trim on the garage door.
    Attached Images Attached Images
  2. #2
    Join Date
    Apr 2000
    Posts
    135
    Kubota B2710
    Default Re: Garage Damage Prevention
    ...and here my sign hanging from the garage door frame. The white vinyl siding is pretty washed out in the picture but if it weren't you'd be able to see the dings in the trim...
  3. #3
    Platinum Member GregJ's Avatar
    Join Date
    Oct 2002
    Posts
    703
    Washington
    Kubota B7500/LA302FEL/4672BH ; John Deere LX277
    Ya know.... I was feeling pretty smug until this last weekend about ROPS vs. garage door frame damage. I haven't nailed my garage door frame in almost a year. I was pretty convinced I had completely overcome this "careless absentmindedness" [img]/forums/images/graemlins/crazy.gif[/img]. This last weekend I carefully went into the house garage to get a load of recycle to take up to the end of the road. I carefully folded the ROPS and took the first load up. And then..... yup... as I came flying down the road to pick up the second load, there was that dreaded cracking sound and sudden "wheelie" type feeling..... [img]/forums/images/graemlins/blush.gif[/img] [img]/forums/images/graemlins/blush.gif[/img] [img]/forums/images/graemlins/blush.gif[/img] [img]/forums/images/graemlins/blush.gif[/img] [img]/forums/images/graemlins/mad.gif[/img] [img]/forums/images/graemlins/crazy.gif[/img] Fortunately, no one was there to witness the event, and the damage was minimal. This had me thinking about anything I can do to help remind my feable mind that I have a ROPS sticking up about 7'6" over my head, before I try to go in a 7 foot opening. For a fleeting moment I even questioned the wisdom of raising the ROPS to do simple tasks around the house, on level ground. Then I remembered how easy this accident happened and realized I am capable of much worse. So..... long winded reply to say ..... Thanks for a great idea! [img]/forums/images/graemlins/smile.gif[/img]
    Greg
  4. #4
    Join Date
    Jun 2004
    Posts
    1,368
    N.E. KY
    Century 3035
    Would it be possible to hang some bells or chimes from the soffit that you would hit first?
  5. #5
    Join Date
    Oct 2002
    Posts
    703
    Washington
    Micropilot,
    Thanks for the thought. However, I think I might have a little trouble getting my resident designer/decorator (aka ... my wife) to allow me to hang "tractor reminder bells" from our house garage, which is a focal point in our main entry. However.... if tastefully done..... maybe you're onto something there. [img]/forums/images/graemlins/grin.gif[/img] Perhaps a mobile of orange tractor silhouettes..... [img]/forums/images/graemlins/smile.gif[/img]
    Greg
  6. #6
    Platinum Member BubbaJr's Avatar
    Join Date
    Mar 2003
    Posts
    596
    Western Ohio
    2016 KUBOTA B2650 w/cab & A/C
    Hi Bill,
    I have about the same tractor you have (B2910) and I got it with the non-folding ROPS. Mine will go under a standard 7' garage door with room to spare. If your door is a standard garage door, you may want to consider swapping out your ROPS with a stationary one. I'm sure your dealer would be interested as there are always people that need a smaller profile.
    It never made sense to me that the folding ROPS was taller than the stationary one. But just so you know you're not the only one that does stuff like that, I installed a bright yellow umbrella from TSC on my tractor. It keeps the sun off me pretty good. But I found out the hard way when going from the barn to the garage the umbrella WILL NOT fit under a standard 7' garage door. I was able to straighten out the bent rib to the point that it is usable again, but it still looks a little lop-sided. [img]/forums/images/graemlins/blush.gif[/img] [img]/forums/images/graemlins/blush.gif[/img]
  7. #7
    Super Member SPIKER's Avatar
    Join Date
    Jun 2002
    Posts
    5,000
    Ohio, Jeromesville, Ashland County
    Jinma 284
    Bcarter:
    with the shape of that sign, someone is going to think you have some sort of SPELLING disfunction! lol I'm sure that many have seen , read and wondered what the heck does that mean! [img]/forums/images/graemlins/wink.gif[/img]
    I would think some small silver bells, (like what is on a weath at winter) hanging from the sofit so they ding ding as you wheel up there..
    this weekend I have an OLD garage/horse/steer barn with dirt floor, my rops which is foldable, wouldn't fit, so I did the logical thing and removed some dirt so it would! lol. actually the thing was built with scrap lumber and is rotting enough at the base so it is sinking into the ground anyway, if it lasts 3 more years I'll be lucky. there was so many wood chuck holes in there I had to box blade out about 4 loads of dirt/manure/hay from probably 5 years back. this leveled the floor enough to get some stuff in there and I'll be using it to store the back hoe and ATV here shortly.
    Mark M
  8. #8
    Join Date
    Apr 2000
    Posts
    135
    Kubota B2710
    <font color="blue"> If your door is a standard garage door, you may want to consider swapping out your ROPS with a stationary one. I'm sure your dealer would be interested as there are always people that need a smaller profile. It never made sense to me that the folding ROPS was taller than the stationary one. </font>
    The taller ROPS is needed for the backhoe... Otherwise I shorter ROPS would be the obvious solution. I'd assume that they make the tall ones fold because they are so tall.
    <font color="blue"> But just so you know you're not the only one that does stuff like that </font>
    You've hit on one of the reasons that I think this site is so great... Lots of other folks are willing to share that they have done the same dumb things that I have! Misery loves company! [img]/forums/images/graemlins/grin.gif[/img]
  9. #9
    Join Date
    Apr 2000
    Posts
    135
    Kubota B2710
    <font color="blue"> with the shape of that sign, someone is going to think you have some sort of SPELLING disfunction! lol I'm sure that many have seen , read and wondered what the heck does that mean! </font>
    My dad was at the house this past weekend and made that exact comment... Thought the sign was really cool, but had no idea what ROPS meant! Its the reason that I decided to share it with you all. I figured at least a few folks here would "get it"... [img]/forums/images/graemlins/grin.gif[/img]
  10. #10
    Join Date
    May 2004
    Posts
    163
    Dutchess County, NY
    Kubota BX23
    </font><font color="blue" class="small">( Bcarter:
    )</font>
    You probably wont be able to hear them over the engine, and if you are wearing ear protection, you'll never hear them.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
© 2018 TractorByNet.com. TractorByNet is a registered trademark of IMC Digital Universe, Inc. Other trademarks on this page are the property of their respective owners.
