I run a
Worksaver HPD-16 post driver and the minimum pto hp recommendation is 30 hp. At least with this Worksaver model, there's no connection to the PTO, so why they list a minimum PTO hp is beyond me. The important number is capacity of your pump, i.e., how many gpms it has. Even then, the gpm of the tractor hyd pump determines how fast the driving ram goes up. Once it's at the top and you push down on the joy stick, the hydraulic fluid is dumped back into the sump and ram drops, by gravity.
I've never used a driver that has it's own pump, but the Worksaver is pretty simple device to hook up (one rear remote connection) and use. I wouldn't mess around with a driver with a separate pump and a PTO shaft, but that's just me. /forums/images/graemlins/tongue.gif
You also have to consider the weight of the driver and make sure that you have enough weight on the front of the tractor. So, if my TC25D (with loader) can handle the HPD-16, the 24 hp Kubota L3130 should too. My opinion. Your Mileage May Vary. /forums/images/graemlins/grin.gif Note, with the Worksaver, the weight is only an issue when lifting the driver for moving it to a new spot. When driving in a post, the driver sits on the ground. However, the tractor gets shaken a bit every time the ram hits the post so a heavier tractor will get shaken less.
As cowboydoc said, a larger driver will not help you drive posts in rocky soil, at least no driver that will fit on a CUT. If there's a big rock directly in the way of the post, the driver will just kinda bounce off the post. If the rock is off to one side, the post will go in crooked. Depending on how crooked, you might be able to use the post as a fence post, sometimes, like doc said, you have to pull the post and try another spot.
This past summer I pounded in 187, 4" x 4" x 8' posts. Put them 3 feet into the ground. I also drove in 40 T Posts. I got to the point where setting up the tractor and driving the post took about 10 - 15 minutes per post. I had laid out where I wanted each post, marked the ground with marking paint and had a post pre-positioned at each mark. I was working alone as well. Some posts took 40 - 50 pounds to go in. The larger Worksaver drivers can handle larger posts, have a heavier ram and could accomplish the same task with less hits.
600 posts is a lot of posts to set, even with a driver. /forums/images/graemlins/blush.gif
Feel free to ask away. I'm not an expert, but I spent a large part of this summer driving posts. /forums/images/graemlins/cool.gif
