ZJ_HR
Gold Member
Hmm, That's not totally correct.
Tractors in Europe which have top speed 40 km/h or more, 2wd or 4wd, MUST have braked front wheels.
There are 3 type of braking on 4wd tractors.
1. Engaging 4wd when brakes are pressed - tractor have on load 4wd engaging with multiplates
2. Independant drum/disk on drive shaft, braked when rear brakes are engaged
3. Disk brakes in front wheel hubs. 4wd can be engaged mechanically. This is only possible way for 4-wheel braking on 2wd tractors.
My SAME tractor has 4-wheel, oil immersed disk brakes. And they have selectable action:
- When press BOTH pedals, all, front and rear wheels are breaked (can't be disengaged)
- When press single pedal, both front and rear wheel on one side, are braked (normal setup) - tractor turns really sharp on grass or on field covered with fresh spreaded manure.
- When press single pedal, just one rear wheel is braked (this can be engaged by turning special valve under dash).
This, 4-wheel brakes option (with front diff. lock) is available on 30 km/h versions, too.
I can say, from personal experience, that stopping distance is very small with 4-wheel breaking, so sometimes is feeling that I'll fly out through front window from cab /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
BTW, NH TN tractors (version 40 km/h) have 4wd breaking by engaging 4wd (type 1), and oil immersed front disk brakes (type 3) are available as option (in Europe, don't know for US).
4-wheel brakes setup is particullary recommended for hills for safety, because, when you engage brake on normal 4wd, one wheel can turn forward, and another one back, and braking possibility is reduced.
