</font><font color="blue" class="small">( By the looks of the broken wheel, to me someone has added a yoke that won't caster. It needs a bent arm from the pivot down to the axle to caster.
)</font>
Good call. If not a bent arm, then atleast something to get the center of the wheel offset from line of pivot. Perhaps a piece between the yoke and the housing for the wheel
For the 3pt, any way you can adjust it so that full down will not scalp while mowing? If not then chains would be the way to go.
Dont be discouraged, your frustrations so far seem simple. Also, dont beat yourself up trying to figure something out yourself when there are plenty of other here who have "been there" and can help you (and everyone else) out. /forums/images/graemlins/cool.gif
PS Draft control is based off of forces in the top link. It maintains a constant force on on 3pt. Too much, and it will raise, too little and it will lower (Thats my best take at it). Best suited for ground-engaging work (like plows so you can maintain depth until something might break), not mowers and the like.
)</font>
